Installing cam without engine removal
Old Feb 13, 2005 | 02:27 PM
chillcat's Avatar
chillcat
Default Installing cam without engine removal
I'm thinking of ordering a set of heads/cam. I'd like to find out if its difficult for a mechanic to swap out a cam in my 85 4+3 and swap out the heads. I don't like the idea of the engine being taken out, but I'd like to get a rough idea of what kind of cost I'm looking at in labor. I will be calling around tomorrow....
Old Feb 13, 2005 | 02:45 PM
vader86's Avatar
vader86
Everything in front of the engine and the radiator will have to be removed, then the engine will probably need to be tilted upwards to get it in.
Old Feb 13, 2005 | 02:50 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
That should do it. Remove the motor mount nuts at the bottom if it's set up that way on an early car, otherwise the through bolts and then raise the engine up in a suitable fashion and it should be do-able.
Old Feb 13, 2005 | 03:41 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
HAD TO REPLACE THE BALANCER SEAL ( #@!%^&* NEW SEAL ), IT WAS A PITA TO R&R THE BALANCER WITH THE ENGINE IN THE CHASIS, BUT WE GOT IT DONE. THE RACK AND CROSS MEMBER ARE IN THE WAY. THE OIL PAN IS EASY
Old Feb 16, 2005 | 07:56 PM
JAKE's Avatar
JAKE
I'ce changed cams in my 86 a few times. Never pulled the engine or even had to jack it up.
The only clearance issue, once the radiator, etc., are out is the harmonic damper puller. I simply unbolted the power steering lines from the rack and pinion and was able to install the puller. It then came right off.
I originally posted power brake; that was a brain fart. Power steering line that bolts right in front of the damper is what I meant to say. Once that line is out of the way, the puller can be attached.
That line will continue to drip power steering fluid once it's disconnected, making a mess. So find some way to block it off. I use a piece of hose with a bolt threaded into the open end.
Jake
Old Feb 16, 2005 | 09:21 PM
Frizlefrak's Avatar
Frizlefrak
On an L98? The balancer will come off and reinstall without removing the steering rack. The puller bolt will fit under the P/S line, and pop that puppy off in about 5 minutes. This was one of the easier parts of my timing chain job.
That said, you DO have to remove the P/S line to use the reinstall tool, so you may as well do that anyway from the get go.
To Installing cam without engine removal
