The fuel filter is located on the passenger side frame rail. I didn't have to drop any exhaust components when I changed mine. Are you having problems reaching it? It's really not a hard job at all, just prepared to get a gas bath...
I can't read the instructions in the tech tip and I didn't see any links. Where did this article come from? I need to change my filter too. Thanks in advance,
I just changed mine yesterday after getting help from the forum. First bleed the pressure from the fuel rail. Then dissconnect the inlet and outlet from the fuel rail. You will need a special release tool for this but they are cheap. Release the tank pressure by removing gas cap. Jack up the front of car as far as possible. Support with jack stands. Loosen the bottom connection between the filter and line as well as the return line. Some fuel will run out. I put a plastic cap on the line to stop the trickle while I removed the filter and line assembly up through the engine compartment. Another good tip was to not totally remove the filter bracket screw. Just loosen it. It would be a bugger to get it back in with the filter and line in the way.
