I got the results from a couple of dyno runs and the air/fuel ratio seems to be a lot richer than I would have guessed. It was measured between 10.5 and 11.8 rather than the 14.7 that I expected. I'm assuming that there would be some variation, but that seems a bit much. Is this normally what you would see on a dyno run at wide open throttle? This is a 1996 LT4 with minimal mods (shorty headers, B&B exhaust). Mucho Thanks!
Reason: inverted the ratio
Thanks, Mo. The air filter is a relatively new K&N. I was wondering if the oxygen sensors could be old/off. I've got around 80k miles on the car and I imagine that the sensors are that old, but I'm not sure since I'm probably the 3rd owner.
Hmm. I don't have LT1 edit. I'll check it out. I might try opening up the intake for a run/measurement and see what that does also. Thanks for the pointers.
Seems that 12.5 -12.75 is "safer" and you are still maximizing torque & power......you might get a little more at 13.1 but with a higher risk of troubles......this is for WOT
14.7 is for cruising looking for max economy & minimal pollution....in feedback loop using O2 sensors...
