intake porting ?
Old Feb 14, 2005 | 11:43 PM
reed62783's Avatar
reed62783
Default intake porting ?
92 lt1
i already have ported heads. am i missing anything by not having my intake ported?
Old Feb 15, 2005 | 12:01 AM
RadPolo96's Avatar
RadPolo96
Well if you have your intake ported it will let more air in and will allow you heads to not be as restricted. You might wanna get a bigger Throttle body as well to help the air flow. The engine will breath better all together.
Old Feb 15, 2005 | 12:57 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
What are the flow numbers on the heads vs those of your stock intake??
FYI, stock TPI runners 1.470" dia flow 200cfm.
Old Feb 15, 2005 | 01:32 AM
BAM92's Avatar
BAM92
Probably would not make a difference unless you go 383 or bigger.
To intake porting ?
