KYB Shocks
Old Feb 15, 2005 | 05:48 PM
bigdreams65's Avatar
bigdreams65
Default KYB Shocks
I need to replace my shocks and I'm looking at the KYB's. HAs anyone used these and if so, how are they. I want to get a little better shock than stock. I am a spirited driver at times but also do allot of long range cruises. I am also looking at the KONI's but they are a little pricey.
Thanks all..
Old Feb 15, 2005 | 05:52 PM
Corvette0096's Avatar
Corvette0096
I have a set on my car and they work very good for the money that is spent..
Old Feb 15, 2005 | 05:53 PM
cv67's Avatar
cv67
St. Jude Donor '05
No problems here either.
Old Feb 15, 2005 | 05:59 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The KYB were on my '88 when I got the car 5yrs ago and I'm quite satisfied with them.
To enhance your spririted driving through twisties, install ES poly graphite sway bar bushings front & rear. They will have no effect on ride quality but greatly enhance flatness in turns.
Old Feb 15, 2005 | 06:16 PM
bobmic93's Avatar
bobmic93
I replaced my blistiens with KYB and there not bad shocks butt they dont absorb bumps in the road nearly as good as Blistiens did. I was hoping for a softer ride. Like the other guy said, "you get what you pay for".
Old Feb 15, 2005 | 06:34 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Try this.....Search Link
Old Feb 15, 2005 | 07:08 PM
myblue91's Avatar
myblue91
There on my 91.Good shock for the money
Old Feb 15, 2005 | 07:26 PM
bigdreams65
I did but didn't get many returns.. It is probably the way I am filling out the search form.
Old Feb 15, 2005 | 07:40 PM
JrRifleCoach
OK heres a suggestion;
In the "Search By Key Word" Block
Type in kyb in the KeyWord field
Select Search titles Only
In the "Search in Forums" Block
Select C4 Corvettes 1984-96
Check ON the block, "Also search in child forums"
Then click on the "Search Now" button
-JRC-
Old Feb 15, 2005 | 08:34 PM
88JDO's Avatar
88JDO
Default KYB's
I replaced the Z52 Bilsteins with KYB's and a lot of my interior squeaks disappeared. I doubt if they would be considered high performance but the ride is smoother.
Old Feb 16, 2005 | 06:04 AM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
I want to get a little better shock than stock. I am a spirited driver at times but also do a lot of long range cruises. I am also looking at the Konis...
You mention some qualifications that sort of oppose each other. My experience has been that between the KYBs and the Bilsteins, the stock Bilsteins are the better shock. The Koni's are better yet, but have their drawbacks depending on your driving style.
I've had Koni Sports, KYBs, and Bilsteins, all on my 88 Z51 and I prefer the Z51 Bilsteins. Koni offered both a red replacement and a yellow Sport version. I felt that the yellow Sport version was too harsh for daily driving in town. Great on the twisties, but even the softest setting is considerably stiffer than stock. The Koni shocks are definately superior to the factory shock in build quality. If I was going with Koni for a daily driver, I'd consider the red stock replacement version.
Feeling every bump in the road caused me to try replacing my Koni Sports with new KYBs. With the KYBs my car rode like a caddy. Notable improvement in town and on bad city roads. Excellent for "long range cruises". They were a very good shock at the price. However... having gotten used to the Koni's superb handling during "spirited driving", I found the KYBs a bit sloppy in the turns.
New Z51 Bilsteins seem to me to be the best balance of ride quality and handling. They just seem to be "matched" to the dynamics of the car. Not quite as soft as the KYBs in town, but a lot softer than the Koni Sports with nearly the same handling in the turns as the Koni.
Old Feb 16, 2005 | 04:46 PM
bigdreams65
-JRC-
This worked.. Thanks for the tips.. I weas putting in to much info I think..
I ordered the KYB's last night. Hope to get them soon so I can start cruising.
To KYB Shocks
