odd problem please help
Old Feb 15, 2005 | 07:37 PM
reed62783's Avatar
reed62783
Default odd problem please help
92 lt1
My cay feels like it isnt getting fuel effieciently. i replaced the fuel filter today and samething. What its doing is when i open her up it bogs down ( like its not getting gas) - it also is very unresponive. I dont know whats wrong.
Old Feb 15, 2005 | 08:15 PM
CFI-EFI's Avatar
CFI-EFI
Check to see if there are any codes set. Then check the fuel pressure.
RACE ON!!!
Old Feb 15, 2005 | 11:10 PM
reed62783's Avatar
reed62783
there are no codes- how do i check the fuel pressure
Old Feb 16, 2005 | 02:56 AM
JCAIRE2's Avatar
JCAIRE2
You'll need to purchase a fuel pressure gauge. About $30 at autozone.
Old Feb 16, 2005 | 03:11 AM
cv67's Avatar
cv67
St. Jude Donor '05
There's a schrader valve (looks like a valve stem tip on a tire)on the fuel rail that your gauge screws into(area by the intake runners). May want to wrap a rag around it as its probably (hopefully) pressurized with fuel. Screw it on with the motor off.
Old Feb 16, 2005 | 03:41 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Get a fp gauge with a hose long enough that you can lay the face under a wiper onto the windshield.
Then go for a WOT run on the expressway and note if fuel pressure jumps to the no vacuum setpoint and holds.
If pressure falls back suspect the fuel pump.
Old Feb 16, 2005 | 11:31 PM
reed62783's Avatar
reed62783
its only at high rpms. it wont do it until aobut shifting time. w/ 3.73 gears im upwards around 6000 rpms.
To odd problem please help
