Antenna repair/replace?
Old Feb 16, 2005 | 11:37 AM
DougSilver's Avatar
DougSilver
Default Antenna repair/replace?
I realize the tech/performance forum may not be the right place but I figured I would start here. This morning when getting to work and turning the car off, instead of the antenna going down smoothly and quietly, I heard a kind of loud "grinding" sound (antenna motor going). When the sound stopped, the antenna was still up. I was easily able to to push back down and have not yet tried turning on the radio. I assume this is symptomatic of either the motor going or maybe the "cord" that attaches the mast to the motor.
Being a 95, I guess it is time for things like this to go wrong. What am I looking at to repair the antenna? I will probably be bringing the car into a shop but just wanted some info so I know what to expect.
Thanks.
Old Feb 16, 2005 | 12:15 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Sounds like what happened on my 93, I bought a replacement mast from Chevy. It was pretty simple to replace, take the locking bolt off the mast(the tool to do this came with my mast), turn on the radio and gently pull up the mast as the motor runs. Installing is the reverse of taking the old one out. Make sure the teeth of the new mast cable are facing the right direction.
Old Feb 16, 2005 | 01:07 PM
DougSilver's Avatar
DougSilver
I was worried that I would have to change out the entire antenna. Does anyone happen to know the part number of the mast?
Old Feb 16, 2005 | 01:42 PM
purplemajesty's Avatar
purplemajesty
Try the last detail, thats where I got mine:
http://tld-corvette.com/catalog.htm
Item # 635595 or just search by catagory
Old Feb 16, 2005 | 02:13 PM
DougSilver's Avatar
DougSilver
Thanks--sounds like a winner. One last question. Will the entire plastic cable come out when I remove the mast even if the cable is broken or will a piece of the cable remain in the "tube". If so, is there a way of getting this out?
Old Feb 16, 2005 | 03:08 PM
JCAIRE2's Avatar
JCAIRE2
If the plastic cable did break, you will have to remove the antenna motor from the car and extract the remaining piece before inserting the new mast. It's not hard and I definately wouldn't pay shop rates to have it done.
Old Feb 16, 2005 | 10:20 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Got mine from eBay for $10 with mast tool included. You will know when you take it out if the nylon gears stripped or if it broke off. If broken then yep gotta get the piece out.
Old Feb 16, 2005 | 10:57 PM
BowTieDaddy's Avatar
BowTieDaddy
Default Been there, done that...
I replaced the mast on my '89 and also my '92. This seems to be an Achilles heel on the C4, but it's easy to get past. The former was a simple replacement, as the entire plastic 'leader' came out intact. It was so simple I felt pretty clever when I finished.
When the '92 didn't go so well (part of the leader was broken off in the motor housing), I was forced to go a little deeper. I took the back portion of the rear fender liner loose (didn't remove the back wheel, but did jack it up a few inches) and was able to remove the entire motor housing assembly. (I don't quite recall the steps, but think it was as simple as removing a couple of 10mm bolts holding the housing to the back structure of the car.)
You can remove a couple of Phillips head screws from the side of the 'receiving' area for the leader (it's greasy inside), then fish out the broken leader. Replace the motor assembly on the car and finish the mast replacement assembly as per the instructions.
I recollect that this whole mess took about an hour. Hope this helps.
Old Feb 16, 2005 | 11:05 PM
WAMRTexas92C4's Avatar
WAMRTexas92C4
Redeasy...
Was this a Harada or Metra mast replacement.
These are the two types on ebay as of now....
Rob
Old Feb 16, 2005 | 11:10 PM
DougSilver's Avatar
DougSilver
I did not yet remove the mast as I do not have the tool gizmo. But the symptoms are that the antenna seems to go up okay but it does not go down when I turn the radio off. If I push it down manually it eventually reaches a point where the motor turns on and then it goes all the way down. I had this happen on another car and the repair was simple (the old mast and cable came out and the new one went in). I guess the best way to go is to first buy the mast and see if that's it.
Old Feb 16, 2005 | 11:13 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I just replaced the whole assembly with a new A/C Delco from TLD. About $90 shipped. I had too many other things to do on the car to fix an old antenna.
Old Feb 16, 2005 | 11:20 PM
DougSilver's Avatar
DougSilver
I found the ones on ebay for $9.95, another one on ebay from The Last Detail for about $30, and GMParts Direct has one for $24. Has anyone tried the $9.95 ones?
Old Feb 17, 2005 | 12:16 AM
BowTieDaddy
PRECISELY the same symptoms as with my '89. Turns out that the mast was bent and wanted to go back into the sleeve, but couldn't because of the bent mast. It made a lot of sense after the repair.
BTAIM (Be That As It May), this is a relatively easy fix for someone with pretty basic skills and an hour to fiddle with it.
HTH - BTD
Old Feb 26, 2005 | 06:10 PM
DougSilver's Avatar
DougSilver
I bought one of the antenna mast replacements on Ebay (for $9.95) and did the fix today. When I pulled the old mast out, I noticed the end of the plastic cable was blunt so I was worried that a small piece of the cable might still be in the motor. Nevertheless, I threaded the new cable into the opening, turned off the radio and kept feeding the cable and mast. At first the antenna did not go down quite all the way (about 1" stuck out). But I turned the radio on and off a few times and pushed the antenna down a bit towards the end and all now seems fine. A pretty cheap ($10) and easy (10 minutes) fix.
Old Mar 3, 2005 | 05:50 AM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
From your description of the end, there is a real good possibility that a small piece of the mast was broken off inside the antenna take-up housing. The housing is big enough inside that it probably will never cause you any problem. The new cable will push it around and away.
I pulled my motor apart to get out the 3" piece that broke off. It wasn't that hard to do, but seeing the space inside, I realized that it probably would have never caused me any problems. If I had to do it again, I'd do as you did and not worry about it.
To Antenna repair/replace?
