Lightweight Alum Flywheel question
Old Feb 17, 2005 | 05:34 PM
Cold_B's Avatar
Cold_B
Default Lightweight Alum Flywheel question
The previous owner of my car put in an alum flywheel. My question is how much RW gain would one normally see on a dyno?
Has anyone ran their car on a dyno, installed the alum flywheel, and then ran again and noted the difference of RWHP?
Just curious really.
Thanks!
Old Feb 17, 2005 | 06:04 PM
Zix's Avatar
Zix
Thanks!
It's not really there for RWHP, it allows the engine to rev quicker. It MAY help with HP but I doubt it would be very noticable.
Old Feb 17, 2005 | 10:22 PM
Photomania's Avatar
Photomania
Look in Ekler's catalog (maybe even their website) and they may mention a number. I think I read somewhere that the aluminum flywheel will boost horsepower by an extra 24 stallions. -- Eric
Old Feb 24, 2005 | 03:37 AM
96CERon's Avatar
96CERon
Default Light flywheel benefits
If I did the calculations correctly this is the benefit of the 13.5 Fidanza vs the 39lb. dual mass. I found a site that says a rule of thumb for kinetic energy reduction is 1 HP per 10 lbs of virtual weight reduction--It is a function of gear and rear axle ratio.
For the 3.45 rear gear:
Trans Gear 1 2 3 4 5 6
Virtual lbs lost 303 203 116 80 56 39
Equiv HP gain 30.3 20.3 11.6 8.0 5.6 3.9
Also check this site: http://www.vetteweb.com/tech/0407vet_flywheel/
Old Feb 24, 2005 | 07:46 AM
Red Tornado's Avatar
Red Tornado
when i bought mine from carolina clutch (13# fidanza), the sales pitch was an average 20hp gain to the wheels. this seems to echo the calculation above.
Old Feb 24, 2005 | 10:16 AM
tjwong's Avatar
tjwong
It basically just frees up Hp that would be required to move the extra mass. So it is a good sales pitch and it is no BS But plain facts and physics.
Old Feb 24, 2005 | 01:46 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I agree. It doesn't ADD or MAKE more power, it just doesn't absorb as much when accelerating as a heavier unit would.
Larry
code5coupe
Old Feb 24, 2005 | 10:25 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
Thanks!
one of the vette magazines did this with Fidanza flywheels a couple months ago, they did two c5's and I want to say one picked up 12 and one picked up 18 - the car with the bigger gains in hp had a lot more mods to start with
I can't find the link but it's online and I know I've got the dang magazine somewhere
Old Feb 26, 2005 | 08:40 AM
96CERon's Avatar
96CERon
Default C5 Light flywheel test is above in my response
I'll put it in again.
To Lightweight Alum Flywheel question
