L98 and 4:11's ??
Old Feb 17, 2005 | 06:38 PM
6spd's Avatar
6spd
Default L98 and 4:11's ??
i did ask this question before but alot of people that replyed had 92 and up vettes.i think 1 person with a l98 has posted. i have alot of bolt on's stock heads and cam. 6spd with 3:45 gears. for around town no track is this worth it?? will it be a big diffrence?? i do plan on getting the superram and manifold but for now i want to do gears. will 4:11's use up my rpm range i don't mind shifting more or faster.
Old Feb 17, 2005 | 06:45 PM
adi4's Avatar
adi4
I have a 1990 L98 6sp and changed my gears from 3.33 to 3.75 it has made a huge difference to mine, IMHO I think 4.11 will be too low , and someone will correct me if I am wrong ......dont you have to modify the casing to fit 4.11 ???? good luck
Old Feb 17, 2005 | 06:52 PM
chriswtx's Avatar
chriswtx
4.11's are too much for a L98. 3.73's are a better choice...
Old Feb 17, 2005 | 06:54 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
hey 6speed, i used to run 4.09 gears in my 89, had headers, small cam, compression, head work and a few other little tricks. in the quarter i ran 12.teens at 107-108, but the 09's were too steep, i would run out of gear on the top end. i was pulling 6g, but my engine was losing power up there. i eventually put in 3.92 which dropped my rpm's down to about 5600, but still losing steam up there. i'm now looking to put in an lt1, so the 3.92 gears should be perfect. if you built an engine that built hp up to 6k, then the 4.11 might be good, but if your hp tops out around 5k-5500, you might look at 3.73. just my opinion, might help.
Old Feb 17, 2005 | 07:11 PM
vader86's Avatar
vader86
3.73 would be as high as I go with a L98, and thats only because it makes 6th more useful.
4.10 would be too much even with the Superram.
Old Feb 17, 2005 | 09:33 PM
6spd's Avatar
6spd
so 3:45's to 3:73's is still a big diffrence??
Old Feb 17, 2005 | 09:55 PM
adi4's Avatar
adi4
as I posted above I went from 3.33 to 3.75 and noticed a big difference so even going from 3.45 to 3.75 you will notice a definate difference
dont forget an L98 dont pull much above 4500 / 5000 ( not without a lot of work ) I think you will be more than pleased with 3.75 . good luck
Old Feb 17, 2005 | 09:58 PM
6spd's Avatar
6spd
thanks
Old Feb 17, 2005 | 10:07 PM
6spd's Avatar
6spd
i almost forgot is us gear a good place to buy them?? also do i buy the complete install kit bearings and everything??
Old Feb 17, 2005 | 10:56 PM
adi4's Avatar
adi4
I bought mine from Merle at EM he has been very helpfull with everything I have bought even down to the shipping to the UK where I live .
as for the bearings that depends how many miles your car has done, I didnt change mine ......having said that my car had only done 22k when I changed them , but I did change the seals while I was in there , it would be a PITA to have to take it out again just to change the seals
good luck
Old Feb 17, 2005 | 11:00 PM
Sleazy Rider
there is a shop around houston, tx called pyle bros. they do rearends all over the states, especially dragsters. he's done 4 or 5 for me, great work.
Old Feb 17, 2005 | 11:09 PM
TIMSPEED's Avatar
TIMSPEED
Depending on price, I wouldn't bother. It may FEEL faster, but when you put it on the track, it MIGHT be .1-.2 faster. Which, for $500, isn't a good deal...
Old Feb 17, 2005 | 11:21 PM
6spd's Avatar
6spd
it's not going on the track around town driving.
Old Feb 18, 2005 | 02:18 AM
88421VETTE's Avatar
88421VETTE
When you start gearing your car traction becomes an issue 4:11's would make 1st gear useless and by the time you hook you have to shift. My bro has a 01 WS-6 T/A and he went from 3.42's to 3:73's and he has major wheelhop issues.
Old Feb 18, 2005 | 08:59 AM
HeeHaw89's Avatar
HeeHaw89
Its true you don't need a lot of gear in an L98. But if you aren't interested in 1/4 times, then it should be one heck of stoplight brawler. I say give 3.73's a try, but hooking will be an issue.
Old Feb 18, 2005 | 09:51 AM
Sleazy Rider
there are a number of drag radials on the market, and m&h has one hell-of-a dot drag tire, 305-40-16, that i use.
Old Feb 18, 2005 | 09:52 AM
loiq's Avatar
loiq
Lots of guys have paid a lot more to get a tenth.
To L98 and 4:11's ??
Old Feb 18, 2005 | 11:37 AM
1990dtgL98squared's Avatar
1990dtgL98squared
I put 4.11's in my L98 (stock heads and cam) for the same reason.
Tell you what, around town, they can't be beat. Tracion is an issue in 1st, but it's not useless.
I am currently siamesing my base to gain some upper RPM horsepower too...
-Dave
Old Feb 18, 2005 | 12:37 PM
neat's Avatar
neat
I'm going 4.09 in my 1991 six-speed. I go to the track quite a bit though, and launch the car on slicks. The lower gears should really help me get out of the hole.
If you want the car to "feel" faster, 4.09's are what I would recommend.
As far as actually racing, the 4.09 gears are going to bring you through the RPM range much faster than 3.73's. The L98, especially in stock form, doesn't make great power above 4,000 RPM's. The 4.09 gears are going to sling the car to that "dead spot" in the RPM band a lot sooner than a higher gear.
It's all a trade off man. It all depends on what you want to do with the car.
Old Feb 18, 2005 | 02:43 PM
LT4BUD's Avatar
LT4BUD
will 4:11's use up my rpm range .
Well, what is your rpm range????? Selecting gear is more than just a wild guess......I assume your interest is 1/4 mile???
With 4.10's 5000rpm will get you about 91mph, 5500rpm will get you about 100mph, and 6000rpm will be about 109mph in 4th gear, assuming about stock size tires....
So where are you going thru the traps now???? speed, gear, rpm??
Do you have dyno curve for your car??
Anyhow my guess is that unless you have upped the rpm range on your L98, you are going to run out of rpms with 4.10's, as noted above...
Oh, around town at the stop light, it will be a hoot with 4.10s, but be ready to shift.....biggest gain is 1st gear, 4.10/3.45 is about equal to 1.18,so it is like increasing your engine torque by 18%
