87 HVAC controls
Old Feb 18, 2005 | 10:54 AM
HamCrab87's Avatar
HamCrab87
Default 87 HVAC controls
Anyone have tips on the HVAC controls? Mine is intermittent, both the lights and the display. What would be a prime suspect, circuit board, power, switch, ??????. As long as it's warm and the top is off who cares ... but on those cold drives to work in winter it's kinda important. Sometimes it gets right toasty and it's hard to futz with it to lower the setpoint when you can't see the display.
Old Feb 18, 2005 | 12:05 PM
jfb's Avatar
jfb
Typical problem. Take it apart and resolder the cracked solder joints. There are a couple of large diameter eyelets that are filled with solder and these solder joints crack. Check all the other joints under magnefication.
Old Feb 18, 2005 | 12:16 PM
HamCrab87's Avatar
HamCrab87
Default thanks for the tip
I was trained in Electronics repair in the mid 70s .... glad to see it will come in handy again.
Old Feb 18, 2005 | 08:44 PM
rick lambert's Avatar
rick lambert
Could be just dirty, corroded connections too-that was my problem.
Old Feb 18, 2005 | 10:14 PM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
I have the 87 C68 AC section from Helms pdf'd. If you want it, PM me with your email address.
Old Feb 18, 2005 | 11:05 PM
87 Ragtop's Avatar
87 Ragtop
CI 3-4-5-6-7-8-9-10-11 Vet
CI X Blind Auto-X Champ
That fixed my problem. Touched up the solder joints.
Old Feb 19, 2005 | 02:44 PM
HamCrab87's Avatar
HamCrab87
Default you have mail
Rich ... I sent you a PM last night. Thanks.
To 87 HVAC controls
