This is a dumb question I know I am probably overlooking the obvious but can someone tell me how to get to my driving (fog) lights?? I am hoping the bulbs are just burnt out.
Just under the front facia, look closely and you will see a door under each driving light. they are easy to get to, once you locate this "secret" door... You may want to read the tech section..there you will find a simple way to improve the lighting, by using 50 watt bulbs, and a slightly larger amperage fuse. Since you will be replacing the bulbs, you might as well get better lighting!
