150 ft lb on u-joint bolt?
Old Feb 21, 2005 | 06:13 PM
kellsdad's Avatar
kellsdad
Default 150 ft lb on u-joint bolt?
My Cobra replica has suspension from a 1987 Corvette. My Corvette auto repair book says the small (8 mm) bolts that secure the u-joint retaining straps should be torqued to 150 foot-pounds. I have yet to find an 8 mm socket capable of withstanding 150 foot-pounds. Can anyone verify the torque specification on these bolts? Thanks.
Old Feb 21, 2005 | 06:18 PM
Pete K's Avatar
Pete K
They require much less. The large nut that is in the center of the rotor requires 150-175 ft lbs. Is it possible you mis read? I normally tighten the u bolt bolts with a small wrench till it hurts my hand a bit. Probably only 5-10 ft lbs with some blue(med) locktite added.
Old Feb 21, 2005 | 06:29 PM
CFI-EFI's Avatar
CFI-EFI
You're going to need a longer lever to it get that tight. My Helms says the pinion nut gets torqued to 200-220 ft.lbs. The straps for the half shafts, 22-30 ft.lbs. And the straps to the pinion yoke, 14-20 ft.lbs. 150 IN.lbs equals about 12.5 ft.lbs. Did you read it correctly?
RACE ON!!!
Old Feb 21, 2005 | 06:30 PM
aboatguy's Avatar
aboatguy
I have 18ft lbs or 24Nm in my chilton's manual.
Still waiting for the delivery of my Helm's manual.
Good luck
Mike
Old Feb 21, 2005 | 06:34 PM
aboatguy's Avatar
aboatguy
Looks like someone beat me to the answer!
Old Feb 21, 2005 | 06:56 PM
kopbet89c4's Avatar
kopbet89c4
RACE ON!!!
Yup, in-lbs.
P.S. They also use that special unit of measure to brag about the torque of mostly stock Honda econoboxes.
Old Feb 21, 2005 | 07:06 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
:igree:
My '88 GM Shop Manual calls for 18 lbs-ft on the nuts holding the U-joint bearing caps on the propeller shaft.
Old Feb 21, 2005 | 08:25 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by 65Z01
:igree:
Nuts??? My car uses straps to retain the u joint bearing caps, into the yoke. The yoke is tapped for the strap bolts.
RACE ON!!!
PS. Some Dana yokes have drilled (not tapped) holes in the yoke to take a u bolt. The u bolts have nuts. Is that how yours is set up?
Old Feb 21, 2005 | 09:30 PM
ALLT4's Avatar
ALLT4
Here's something handy to have.
http://chiphead6.homestead.com/files...onversions.htm
Right click "save target as" if you want to save it. I find it more convenient sometimes to just have it on the old PC.
Old Feb 21, 2005 | 11:17 PM
87NassauBlue's Avatar
87NassauBlue
You'd definately break or strip those small bolt with that much torque. You book certainly was talking about the pinion nut. I just put them in with an air ratchet or open end wrench and seat them well. Last time I was over careful using torque specs on something like that caused me a lot of extra work. I torqued a valve body in a tranny down according to specs and ended up with bad cross leaks. Every time I do it according to feel, I'm just fine.
Old Feb 22, 2005 | 08:27 AM
kellsdad's Avatar
kellsdad
Thanks guys. I thought the correct torque might be 150 inch-pounds, but my cheapo manual has it listed as foot-pounds.
Old Feb 22, 2005 | 10:42 AM
CFI-EFI's Avatar
CFI-EFI
Order a HELMS manual. They have less mistakes and can save time and money, trouble shooting systems and components.
RACE ON!!!
Old Jun 2, 2005 | 06:59 AM
Casethecorvetteman's Avatar
Casethecorvetteman
And which particular service manual would this be??
To 150 ft lb on u-joint bolt?
