Cant decide on mufflers-----
Old Feb 22, 2005 | 06:43 PM
reed62783's Avatar
reed62783
Default Cant decide on mufflers-----
92 lt1- large cam
I cant decide on mufflers- i think i like the magnaflows. but i havent heard very many. i know i dont want a corsa and flowmasters create alot of resonance. so any other ideas?
Old Feb 22, 2005 | 09:13 PM
nearmiss's Avatar
nearmiss
I installed B&B triflows (3") in my 96 LT4 and like the way they sound and look. There's a little resonance around 2k rpm, but I'm either above that or below it most of the time. They're pricey at around $1k and required a bit of "tweeking" to get them to fit. B&B says its an issue only with the 96, but who knows? I almost went with magnaflows and probably would have if they would have had a complete system for the 96 like they do for the earlier years.
Old Feb 23, 2005 | 12:16 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
I've got Hooker AeroChambers in mine
I just bought the mufflers and welded those in place of the stock barrels. Cost me $60 each and they sound gooooood
Old Feb 23, 2005 | 01:48 AM
cv67's Avatar
cv67
St. Jude Donor '05
Hows the interior resonance? Is it a corvette specific aerochamber or a standard issue?
Old Feb 23, 2005 | 11:23 AM
Strick's Avatar
Strick
I'm a B&B guy. They were much quieter than I expected. Some resonance at 1700-2000rpm if in 6th gear under 55mph. Bad part of B&B is the clamps, they just don't tighten the system enough. I welded mine. Great looking system.
Now I found out that you have options on the B&B catbacks, You can get an X-pipe instead of a resonator (louder and lots of res) and you can get a resonator that doesn't snake down to 2 3/4"
Old Feb 23, 2005 | 12:48 PM
TankerVette's Avatar
TankerVette
I'm gonna throw this out there...
Installed EM longtubes, went to the OEM resonator and mufflers...
You can see my other mods...
I like the sound. Subdued when crusing, Nasty when I get on get in it...
And saved a minimum of $500...
Old Feb 23, 2005 | 03:48 PM
Lichen's Avatar
Lichen
I installed the 3" B&B with EM longtubes. Like Strick said, a little bit of resonance aroung 1700 rpm, but worth the looks and mean sound.
Old Feb 24, 2005 | 01:14 AM
SHINOBI-X's Avatar
SHINOBI-X
LT1....you don't need no stinking mufflers on that baby! let her roar! no mufflers here,i love em'! i say no more
Old Feb 24, 2005 | 02:15 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If you can't decide, then just don't get any mufflers at all.
Straight pipes are cheaper. Aftermarket mufflers are just resonators anyways.
Old Feb 24, 2005 | 10:23 PM
mjones's Avatar
mjones
I too vote for just doing away with the mufflers, or just delete your cats and keep the mufflers.
Old Feb 24, 2005 | 11:14 PM
kwik_ta's Avatar
kwik_ta
I bought the standard issue 2½ offset in center out. I welded it up myself... went up perfect. I don't see why people are so willing to pay the Corvette tax on exhaust when you can get good mufflers and save the $$$ for other mods... although the B&B does look sharp
Old Feb 25, 2005 | 12:35 AM
SHINOBI-X's Avatar
SHINOBI-X
wheres Bogus on this one J/K!
Old Feb 25, 2005 | 12:55 AM
reed62783's Avatar
reed62783
cats are already gone- do yall think i would gain any power by going to a diff mufler over stock? does the stock muffler flow good enough? i am all about saving money
Old Feb 25, 2005 | 03:21 AM
cv67's Avatar
cv67
St. Jude Donor '05
To Cant decide on mufflers-----
