Rebuilding my ac compressor need help!
Old Feb 22, 2005 | 10:10 PM
pletner's Avatar
pletner
Default Rebuilding my ac compressor need help!
I'm replacing the shaft seal and some gaskets in my compressor, but I need to know the oil capacity since I had to drain the compressor. I checked my shop manual but no luck. Anyone have any ideas?
Old Feb 23, 2005 | 02:19 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
It's eather 4 or 6 oz its been along time since I have done one.
Old Feb 23, 2005 | 02:55 AM
korvette4u's Avatar
korvette4u
where did you get the parts from? any part#'s?
Old Feb 23, 2005 | 06:13 AM
pletner's Avatar
pletner
I bought a gasket set and a shaft seal kit from www.acsource.com they have alot of stuff. On the site they ask you what type of compressor you have and mine is a nippondenso 10pa20c, so I just ordered the parts for that specific compressor.
Old Feb 23, 2005 | 02:17 PM
SunCr's Avatar
SunCr
System capacity is 8 ozs and if it was leaking for any length of time, there's probably little oil left in it. I usually put 4 in the compressor and 4 in the accumulator (which you should also replace), but you can spread it out (depending on what's accessible and is being replaced) by putting 2 in the compressor, 1 in the condensor, 2 in the evaporator and 3 in the accumulator.
If you go the 4/4 route, you can turn the compressor shaft clockwise after you pull a vacuum. This will force some of the oil out and into the condensor line.
Do replace the orifice. A leaking shaft seal causes the compressor to shed a little more metal and can plug it up (I found this out the hard way - after I had charged it - the first time I rebuilt one).
Old Feb 23, 2005 | 07:48 PM
pletner's Avatar
pletner
Thanks SunCr! Your right, I only had a coke bottle cap full of oil in the compressor due to my leaky seal. I will do as you recommend!
To Rebuilding my ac compressor need help!
