Intermittent PKE problem
Old Feb 23, 2005 | 12:58 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Intermittent PKE problem
Sometimes when I turn my key on, the PKE light on the DIC will light up and sometimes it won't. Also, when I am driving the will come on for a while, then go off.
Question, is there a ground somewhere I should check or is the receiver bad?
Should note also, I just bought the car. The PKE fuse was missing when I bought the car. Also, since I put the fuse back in, the speedo LCD stays on after the I turn off the car and pull the key. This has happened only twice in a week.
