Tires??
Old Feb 25, 2005 | 09:45 PM
qws's Avatar
qws
Default Tires??
I'm sure this is gonna be a dumb question but anyways. I have an 84 will 315/35/17 inch tires fit the back? I was told they will but now after seeing them I'm not sure. I can't try them just yet the car is in getting ground effects and hood scoop installed and it won't be done till next week. But I'm getting a little nervous whether they will or not.
thanks in advance
Old Feb 25, 2005 | 09:55 PM
Mikez40's Avatar
Mikez40
With the proper offset, I think its 36.5mm offset on an 11" rim will fit.
bogus's Avatar
bogus
They require a spacer... cause the wheels from later vettes have a different offset.
After Mike's post, I need to clarify.
The ZR1 had a different offset then the Grand Sport's. What I don't know is what spacers go with which wheel.
Old Feb 25, 2005 | 09:59 PM
qws's Avatar
qws
Here are my rim sizes 17 x 9.5 (+38mm,6.7" backspace) front and 2-17x11 (+36mm, 7.397" backspace) rear.
Old Feb 25, 2005 | 10:12 PM
Mikez40's Avatar
Mikez40
If you get the ZR-1 offset (36mm) in the back you will not need spacers. And if you get the proper offset for the front you will not need spacers.
If you buy a 17 x 9.5, "38mm,6.7 backspace" for the front, then you will not need spacers for the front.
Old Feb 25, 2005 | 10:18 PM
JackDidley's Avatar
JackDidley
I have 17x11 ZR1s with 315s. No spacer needed. Just ask for the correct offset when you get wheels.
Old Feb 25, 2005 | 10:40 PM
qws's Avatar
qws
it definetly sounds like I got the right rims and should have no problems with the wheels and tires fitting correctly. thanks guys
Old Feb 26, 2005 | 09:44 AM
sniperdiver37's Avatar
sniperdiver37
I was thinking the same thing whem my 315 were sitting on the shop floor. There is no way those will fit.....
Well they will.You have about 1/2 inch clearance from your rear brake lines.be sure to run you hand behind and check it.also when it's jacked up, get under and look for rubbing.
It's a great look and feel
To Tires??
