weird scanner readings?
Old Feb 26, 2005 | 06:48 PM
eboler's Avatar
eboler
Default weird scanner readings?
I hooked up a scanner for the first time today, and got some strange readings. It was giving me random errors, and saying my coolant was running at 124.7. It also said I was moving 5 mph, and that I was running rich. This was when I gave it the correct VIN numbers (4th vin number being Y). I played around with that, and when I told it the 4th VIN number was F, it gave me the correct readings. What could be causing this?
Thanks in advance to anyone who has input!
PS: Using an Autoxray EZ-Scan 6000
Old Feb 27, 2005 | 02:17 AM
bogus's Avatar
bogus
more details about your car, please.
Did you update the ECU?
Old Feb 27, 2005 | 09:21 AM
eboler's Avatar
eboler
I've never touched the ECU, but I'm guessing the guy who had it before me did if that could be causing it. How could I check?
Old Feb 27, 2005 | 02:08 PM
SunCr's Avatar
SunCr
I'd make sure that the latest software is programmed into the scanner. Check the manufacturer's web site and see if there's a download.
Old Feb 27, 2005 | 11:45 PM
eboler's Avatar
eboler
Didn't think of that, thanks.
To weird scanner readings?
