Brake Pads$$$
Old Feb 27, 2005 | 03:44 PM
UCFVetteLt4's Avatar
UCFVetteLt4
Default Brake Pads$$$
I need some front brake pads badly on my LT4. I called around and the original equipment AC Delco's are like $220. I dont have that $$ to spend right now. Are there any cheaper pads that are just as good as the originals. And what is the proper technique for breaking in new pads.
Also what year did they make the ZR1 brakes standard, and is that why its so expensive.
Old Feb 27, 2005 | 03:50 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Hawk HPS or EBC green.
J55 calipers became standard in 95. The pads are the same for the J55 and JL9 calipers. Just the throat is a different width and the calipers are a bit larger in size overall.
Old Feb 27, 2005 | 03:52 PM
NightFlight's Avatar
NightFlight
MAM has OEM for 89-96 front, $129; they also have non-OEM for $79. It's a little cheaper and I'm sure other's can provide advice on other places to look.
Old Feb 27, 2005 | 06:12 PM
Rays91L98's Avatar
Rays91L98
Here is what i use and where I get them.
http://www.brakewarehouse.com/ebc2.htm
Old Feb 27, 2005 | 07:14 PM
CF6873's Avatar
CF6873
Raybesto makes a good product and can be found at Pep Boys. The PG series is what they call Professional Grade and is a very good pad. If you would like your wheels to stay cleaner you might want to try the Quiet Stop ceramic pads. Either one should cost less than OE.
Old Feb 27, 2005 | 07:18 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
The dealer is kicking your ***, my buddy is the parts manager at a chevy dealership. I bought pads for my 93 from him o.e.m. pads $40.00
gotta love the corvette tax.
Old Feb 27, 2005 | 07:30 PM
black85's Avatar
black85
I like my Hawk HPS. They aren't that great cold, but on the second stop they are great. The first stop takes more peddle pressure, but it isn't so bad that it is dangerous or anything.
Old Feb 27, 2005 | 08:29 PM
mesteffen's Avatar
mesteffen
I have the raybestos. they seem like a good pad.
Old Feb 27, 2005 | 10:31 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
I got the PFC z rated from autozone, about $200 for 4, but free lifetime replacement. Grip great when warm (much better than stock), but will squeak if you don't heat them up every 2 weeks or so. If you are planning on autocrossing at all i'd definately reccomend them.
Old Feb 28, 2005 | 08:27 AM
runner140*'s Avatar
runner140*
Default Take a look a AutoZone.....
They have a PFC's Z rated that are great. No dust, work with heat and have a lifetime guarantee.. I think $69.00 for the front set.
Old Feb 28, 2005 | 08:40 AM
rws.1's Avatar
rws.1
PFC- Z rated
To Brake Pads$$$
