Vortech V-2 on a modified engine?
Old Feb 28, 2005 | 12:35 AM
chriswtx's Avatar
chriswtx
Default Vortech V-2 on a modified engine?
Will an intercooled Vortech V2 system be able to keep up with my motor at 6-8psi of boost. My engine runs up to 7200rpm easily and I am worried it wont keep up. I found a good deal on a system with the Carrol bracketry. What do you guys think...I am planing on switching my cam to a bigger roller designed for boost. See my sig for the current setup.
Old Feb 28, 2005 | 01:38 AM
Mo_Bandy's Avatar
Mo_Bandy
Chris the V2 will support 680 hp max CFM is about 1000 . I would be more concerned about your rpm's the V2 limit is like 53,000 rpm even though some run them higher. With a 3.125 you are maxed at about 6200 rpm.
Talk to Greg Carroll ( Blowerworks) he is extremely knowledgable and can give you a definative answer with your mods. Tell him Mo sent ya
I'm thinking you would be ok but you will be towards the top end of a V2 S trim...
Mo
