Fuel Injector Wire Connectors - Please Help
Old Mar 1, 2005 | 11:31 PM
Trizney's Avatar
Trizney
Default Fuel Injector Wire Connectors - Please Help
Ok, I took pictures of all the wiring before i pulled it all apart, but i don't know where the memory stick is
I know that 2 of the injector wires didn't crossover each other, and the others all did.
Can someone look at their LT1 and see how the injector wires are for each set of injectors?
TIA,
Trey
Old Mar 2, 2005 | 12:02 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If they are batch fire it won't matter, but I think at least some of the LT1s were sequential.
Lets get some LT1 guys in on this one.
BTW, are all the injector wire colors the same (good indication of batch fire)?
Old Mar 2, 2005 | 12:38 AM
bogus's Avatar
bogus
sequencial injection started in 1994.
Old Mar 2, 2005 | 12:44 AM
Trizney's Avatar
Trizney
This is a 94, and I checked all the wires, and none of the pairs are the same colors.
Old Mar 2, 2005 | 12:46 AM
bogus's Avatar
bogus
you will need a helm manual. It will make this so much easier.
Old Mar 2, 2005 | 01:45 AM
Trizney's Avatar
Trizney
I got a Haynes, and it sucks for the later model cars. The diagram shows all the wires for the passenger side to be the same colors, and all the wires on the driver side to be the same colors.
Old Mar 2, 2005 | 02:43 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I have a Chiltons and the 2 factory manuels!and for the life of me I can't figure out what you are asking for?
But I think you mixed up your injuctor wires?
I will give some info .
Drivers side front number
1 cylender orange /black
2 orange/blackorange
3 orange/blackyellow stripe
4 orange/red
Is this what you want?
Old Mar 2, 2005 | 02:47 AM
REDC4CORVETTE
If this is what you want here is the other side.
passenger near raidator front.
1 orange/backgreen
2 orange/green with black stripe
3 orange/yellow black stripe
4orange/bluewhite stripe
Old Mar 2, 2005 | 04:14 AM
REDC4CORVETTE
?is this what you needed?
Old Mar 2, 2005 | 07:05 PM
Trizney's Avatar
Trizney
Yes, thank you. That is exactly what I needed.
Thank you.
Old Mar 2, 2005 | 07:43 PM
Trizney's Avatar
Trizney
Ok, I finally found my memory card, and this is how everything was originally:
Cylinder
1 - Orange - Black/Orange
2 - Orange - Black with Dark Green Stripe
3 - Orange - Black
4 - Orange - Black with Light Green Stripe
5 - Orange - Black with White Stripe
6 - Orange - Blue with White Stripe
7 - Orange - Black with Red Stripe
8 - Orange - Black with Yellow Stripe
REDC4CORVETTE, this doesn't match what you wrote, and this is how the car came originally to me. I only have a yellow wire on the passenger side. I have been chasing down an issue with the car losing power, and maybe this could be it.
Old Mar 3, 2005 | 12:12 AM
REDC4CORVETTE
That is the way my car is and I turn 11's with it at 121 mph so I know mine is ok.
Old Mar 3, 2005 | 02:09 AM
Trizney's Avatar
Trizney
Not to doubt you, just to get a 2nd opinion, I called the Corvette Shop local to me, and he said the exact same as you. None of the fuel injector wires should be crossing, and we matched color for color of what the shop manual says.
I drove the car around and it feels the same. Weird.
Thanks for your help.
To Fuel Injector Wire Connectors - Please Help
