L98 Flywheel
Old Mar 4, 2005 | 03:07 PM
Old182A's Avatar
Old182A
Default L98 Flywheel
All, the starter on my 91 auto L98 seems to have a flat spot on it and I want to replace it. Sometimes it just "clicks" for few tries, then starts; other times it starts normally. Battery's good and after it starts, it runs great. My questions are: Does this engine have a 153 tooth or 168 tooth flywheel? Is a gear reduction performance starter the way to go, or is OEM ok? The engine's bone stock and there's no major mods in its future - I just enjoy the ride. Thanks in advance.
Joe
Old Mar 4, 2005 | 04:00 PM
SupaVette's Avatar
SupaVette
Are you sure it's not the solenoid in the starter going rather than the fly wheel? I normally find it's the starter at fault more than the flywheel
Old Mar 4, 2005 | 04:01 PM
SupaVette's Avatar
SupaVette
Ok never mind, i didn't read the question properly, it's late
Old Mar 4, 2005 | 04:07 PM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
All C4’s use a 153 tooth flywheel, and the stock mini-starter for 91 is just fine as a replacement
Old Mar 5, 2005 | 03:14 AM
85 500 horse's Avatar
85 500 horse
I happen to have a starter that just came out of my 85. It had 52K on it and I took it out to go with a high torque unit due to mods. There's nothing wrong with it and it's yours for $35 plus shipping. Send me an email if interested.
Old Mar 5, 2005 | 03:23 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
My L98 86 has 168 teeth .
Jegs has a high tq starter for 138.00 on sale this mth and it will fit 168 or 153 tooth I bought one .
Old Mar 5, 2005 | 01:37 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by REDC4CORVETTE
My L98 86 has 168 teeth.
That is not stock.
RACE ON!!!
Old Mar 6, 2005 | 03:02 AM
olman's Avatar
olman
Originally Posted by CFI-EFI
That is not stock.
RACE ON!!!
I couldn't get 168 tooth flywheel in mine. As for the original question, sounds like a solenoid problem to me.
Old Mar 6, 2005 | 03:22 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Hey Joe,
If you want to get your starter fixed,I highly suggest you get yours rebuilt and not"exchanged" with a core from the parts stores.
I forget the flywheel tooth but its very important to see if your
starter has any shims or not.Many times,when you swap starters with the parts stores,they dont fit right without proper shimming,which is a pain in the azz.Usually its not the same as the one in your car.
Check this out before swapping starters.
Btw,Im a former NewYorker and lived in Westchester county and Fishkill area in the Past.Hope the Vette gets fixed for ya!!
Old Mar 10, 2005 | 12:08 PM
Old182A's Avatar
Old182A
Thanks for all the good feedback, gang. John, I took your advice and ordered a starter from Jegs (w/solenoid and shims: $148 incl. shipping) as I wanted a new unit in the car.
Bill: 22+ years at Texaco Research - great ride!
Joe
Old Mar 10, 2005 | 12:45 PM
scorp508's Avatar
scorp508
I hope you went with a mini-starter. The full sized ones are such a bear to work with.
Old Mar 10, 2005 | 12:47 PM
IBEAM700's Avatar
IBEAM700
Yeah, their heavy too
Old Mar 11, 2005 | 09:57 AM
Old182A's Avatar
Old182A
Uh oh. I ordered part #555-10001 - I think it's full size, but has an adjustable mount, weighs 10.5 lbs. Well, maybe it'll take a few extra beers and cigars....!
To L98 Flywheel
