I'm thinking about doing the T/B bypass..
Old Mar 10, 2005 | 11:14 PM
nitronick's Avatar
nitronick
Active Streak: 90 Days
Default I'm thinking about doing the T/B bypass..
1985 Coupe, 4+3.
What affect does it have on cold starting? Will it throw a code at any time warm or cold?
Old Mar 10, 2005 | 11:22 PM
VAHROOM's Avatar
VAHROOM
It did make a small difference on my 90 here in AZ as far as HOT weather driving. It seemed it didn't lose as much power when it was over 110. I don't have any real data to back it up. I didn't notice a difference in the cold though. I didn't see any performance difference either. It did clean up the look of the engine compartment a slight bit.
Old Mar 10, 2005 | 11:37 PM
JAKE's Avatar
JAKE
Originally Posted by nitronick
1985 Coupe, 4+3.
No code, only the possibility of butterfly icing during certain climatic conditions.
Jake
Old Mar 11, 2005 | 01:01 AM
nitronick's Avatar
nitronick
Jake
Well, if it's THAT cold I ain't gonna be drivin' it anyway!
Old Mar 11, 2005 | 01:12 AM
JAKE's Avatar
JAKE
I don't recall the exact temp #s but it's something like outside temps in the mid 30s or so and high humiditiy.
By-passing it does not set a code; there's no code for that in the ECM. The system will never even know you did it.
Jake
Old Mar 11, 2005 | 01:41 AM
olman's Avatar
olman
I did it years ago. Waste of time.
Old Mar 11, 2005 | 01:53 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
If it's not broke, don't fix it.
Old Mar 11, 2005 | 02:34 AM
nitronick's Avatar
nitronick
Well that's a little warmer than I thought you were talking about. I have had the vette out in those temps. I didn't like it, since my heater temp selector is stuck to the cold side!
Jake
I was mainly concerned with it affecting the IAC. Causing it to set a code.
Old Mar 11, 2005 | 03:51 AM
TA's Avatar
TA
Maybe from a performance stand-point, but it sure makes removing the throttle body a breeze.
Old Mar 11, 2005 | 04:54 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Waste of time unless you remove your throttle body alot.
All I noticed is it got my opti wet and caused more problems than it was worth.
Now I juice it so it made it easier to set up the nitrous plate.
I think the mod rates up their with the air foil,!/2 inch spacer for the throttle body,adjustable fuel regulator,and mass air flow housing.
Old Mar 11, 2005 | 07:49 AM
runner140*'s Avatar
runner140*
Default It's a better idea if you live in.....
If you live is South Florida, Az. or Cal. It is for reducing heat in the T/B. In most states, reducing the temp. in the T/B is not necessary. In South Florida reducing the temp. in the T/B, during the summer, is necessary.
Old Mar 11, 2005 | 09:59 AM
AGENT 86's Avatar
AGENT 86
I did it because it cleans up the engine bay. I went as far as removing the coolant passage and nipples from the TB
To I'm thinking about doing the T/B bypass..
