Eliminating Cats
Old Mar 10, 2005 | 03:45 PM
ScaryFast's Avatar
ScaryFast
Default Eliminating Cats
What's the best way to eliminate the cats on a 1993? Does anyone make a decent X or H pipe to bridge the gap between the headers and the cat-back exhaust (if it matters, I have a Borla system).
Any suggestions would be appreciated.
Thanks.
Old Mar 10, 2005 | 03:50 PM
VAHROOM's Avatar
VAHROOM
Mine just has short pipes that hook up between where the cats would be and the headers. They have a flange welded on the outlet end and hook to the headers on the inlet. This just ensures that if I want I can put the cats back on with ease. Most muffler shops will make a "test pipe" like that for you.
Old Mar 10, 2005 | 04:55 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
I hope Bogus doesn't see this
Old Mar 10, 2005 | 05:05 PM
odysseysteve's Avatar
odysseysteve
I hope he does!
Old Mar 10, 2005 | 05:17 PM
VenkmanP's Avatar
VenkmanP
IBTB
(Before the Bogus)
Old Mar 10, 2005 | 05:35 PM
ScaryFast's Avatar
ScaryFast
Looks like the TPIS long tube headers eliminate the cats, anyway. Do the Hooker long tubes? Anyone prefer one over the other if I go that route?
Old Mar 10, 2005 | 05:50 PM
bogus's Avatar
bogus
Glad I didn't disappoint.
I am curious, why do you want to ditch the cats?
They don't rob power... modern cats are most efficeint. Factory LT1 cats are only robbing about 5hp.
Here is the other part of the equation - cats provide necessary back pressure to allow the exhaust to scavange correctly.
The final part? Air quality. As long as a car is used on the highway, I will support the use of cats and EGR to keep emissions down. (note on the EGR, modern engines don't use it thanks to different cam overlaps and better computer controls)
I am a realist - precats and airpumps are a waste of space... If I could, I would ditch both off of bastet44's 87 coupe. But the main cat and the EGR are what really matter to air quality.
Headers only eliminate the factory cats. They are so big, they won't move down the car without bumping things. I would suggest bullet cats from Magnaflow (CarSound) or Random Technologies. Either way, they are about $140.00 each or so.
Is this car going to be a dedicated track car? If so, then you won't need them, and you can ignore my rantings.
Old Mar 11, 2005 | 09:22 AM
Lichen's Avatar
Lichen
So what do you do? Slip the cats back on every 2 years for emissions?
Old Mar 11, 2005 | 10:13 AM
cv67's Avatar
cv67
St. Jude Donor '05
For 5 hp, its not worth the hassle IMO.
To Eliminating Cats
