Pushrod Length
Old Mar 6, 2005 | 11:01 AM
Thatthingsscary!'s Avatar
Thatthingsscary!
Default Pushrod Length
Anyone out there using a small base circle hydraulic roller ,with comp retro fit roller lifters and 23* heads If so , what length pushrod did you use ? ........ Thanks !
Old Mar 6, 2005 | 11:24 AM
CFI-EFI's Avatar
CFI-EFI
You will have to get an adjustable push rod and set up the correct geometry of the valve train and buy a special set of push rods to work with your combination of parts. There is no universally correct answer to your question. What worked for someone else may (probably) not apply to your engine.
RACE ON!!!
Old Mar 9, 2005 | 11:19 AM
Thatthingsscary!
You are right about that ! I was just looking for a reference point , because they make pushrod checkers in different lengths , one up to 7.50 , and from 7.50 up to 8 point something . I normally use a solid lifter and a .100 longer pushrod to start , then make my own pushrod checker out of 5/16 steel rod to get it exact ! But with a hydraulic you have to account for the plunger in the lifter ! And so on ............
To Pushrod Length
