L98 rev limiters
Old Mar 7, 2005 | 06:04 PM
ls5454's Avatar
ls5454
Default L98 rev limiters
I have a 90 l98- if it doesn't have a useful limiter (as I've heard) can I buy one? I can't watch the rpms that closely while auto crossing!
BTW: why would GM set the fuel cut-off @ 10,000 rpm- wouldn't the engine blow up before that ?!?!
Old Mar 7, 2005 | 06:25 PM
VAHROOM's Avatar
VAHROOM
Default I don't know this but I think
I believe it is because the TPI manifold itself is a good rev limiter.
I couldn't get my tuned stock 90 TPI above 5500 easily. By then it was running out of umph. It should have been safe for another 500 rpm or so.
You can get an MSD6AL for it and have a limiter and a better ignition.
Old Mar 7, 2005 | 07:03 PM
scorp508's Avatar
scorp508
You can program your chip for a lower RPM. It is a fuel cutoff limiter, not a spark cutoff which is safer on your engine.
Old Mar 7, 2005 | 07:37 PM
vader86's Avatar
vader86
GM left it so high because the TPI limits you better than any spark or fuel cutoff.
With the TPI on there, theres hardly any way you can rev it high enough to run into valvetrain or bottom end problems associated with overrevving.
Old Mar 7, 2005 | 09:26 PM
ls5454's Avatar
ls5454
Thanks for the input guys. I'd still like to hear any/all alternatives/fixes. And as for GM, I hope you're right, but why bother putting one that high? At best it's a waste of code. All I know is it doesn't seem too hard to run up to 6K for me. Perhaps I had that S2000 too long.
Bill
Old Mar 7, 2005 | 10:57 PM
scorp508's Avatar
scorp508
I just edited my post. I have no idea why I put ET. I meant to put RPM.
Old Mar 7, 2005 | 11:48 PM
brogden31's Avatar
brogden31
get the msd digital 6 and 8.8 wires my l98 runs like new perfect acceleration easy rev limits to the 100ths a standing rev limit and a top end rev limit
Old Mar 8, 2005 | 08:25 AM
ls5454's Avatar
ls5454
Thanks. I will get an MSD rev controller this week.
Old Mar 8, 2005 | 08:32 AM
Solofast's Avatar
Solofast
Default shift point
If this is a stock L98 you should be shifting at 4500 rpm for best acceleration. We did extensive testing at the strip and for a stock L98 that was the fastest.
If you are coming up on a corner and don't want to shift up and then back down, you can hold the gear for a bit but if you find that you are getting up near the redline you should have shifted up a long time ago....
You are better to learn to shift it by ear. After you get used to shifting at 4500 you will get to know the pitch and then you don't need to see the tach anymore.
Old Mar 8, 2005 | 09:23 AM
ls5454's Avatar
ls5454
I agree with that, but I don't want my car to suffer during my learning curve. And I have baggage from rev limited cars like Miatas and high revving cars like S2000's. This my first season with this car or anything like it.
Old Mar 8, 2005 | 09:34 AM
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
CI 4-6-8 & 10 Veteran
St. Jude Contributor
Something to consider:
I don't know off the top of my head how much a MSD costs, but if you are really concerned, you might spend less money just buying a set of good Valve springs. I imagine in the world of high-performance valve train parts, a set of springs that can handle 7500 RPMs are easy to find. If you can get a set that are designed for 7500 RPM (Which you will NEVER hit in an L98) for cheaper than buying (and installing) an MSD, then you will have come out ahead.
Just a thought. - I'm not an enging builder, but there is usually more than one way to 'skin a cat'.
Old Mar 8, 2005 | 09:51 AM
ls5454's Avatar
ls5454
Nice convertible, Fozzy. Mine's a triple black 6spd 90.
Interesting idea. I'm not sure what goes first when you over rev. Apparently the rev controller is about $130.
Old Mar 8, 2005 | 10:43 AM
LD85's Avatar
LD85
MSD makes a Rev Limiter box alone. Only cost @ $60 if I remember right, check eBay.
http://www.msdignition.com/rpm_1.htm
To L98 rev limiters
