rotor re-surface questions
1. Can I re-use brake pads I have previously taken off the car, as long as these pads have plenty of material (they are almost new, 80% left) and use with the same exact rotors? (also, I have not changed pad materials, all very close to stock material--no ceramic)
2. When I change pads--mechanic always wants to re-surface. Is this really necessary or BS? I have heard it both ways and I tend to believe it is BS, not necessary. For my wife's Neon, I just put the pad on there and it seems fine.
Thanks,
A
Should not be a problem in your case.
It's only necessary if the rotor is scored/worn beyond a certain depth. The GM manual gives that depth...
Larry
code5coupe
if the rotor is worn (too thin), replace them.
another reason to turn the rotors is if they're POS to start with and have significant runout.
Thanks,
A
Depending on track, be sure to get some cooling air to the brakes or you risk boiling the fluid on a C4 as you become more comfortable with the car.
If your putting a used pad on a used rotor expect used Brake performance. Not bad but not right.
If he is ASE certified its because he paid attention to his test and the brake part manufacturers. Resurface to the right RMA finish is required for proper break in, life and performance. Not resufacing is a cost cutting effort during warranty work at the dealer its about saving an hours labor.
On the other hand You resurface a cylinder head for truness and finish but not the block when you replace a head gasket both sides seal. Why because the gasket absorbs the imperfections and does the job it was designed for. If you dont resurface the rotors your asking the pads to do something they were not designed to do. No Brake manufacturer recommends repair this way but its done every day with satisfactory results. Not right but ok.
Thanks,
A
Thanks,
A
Didn't think so.
If he's talking about turning the rotor, then no, as already mentioned.
Technically turning a rotor is only done when the rotor has a variation in disk thickness. Even run-out should be handled with different methods.
If he's talking about "hatching" the rotors, then it's a good idea. But you can do it yourself very easily.
Basically it's just a fine abrasion disk lightly worked over the rotor surface. Which leaves a "hatch" pattern.
You can get 3M rotor resurfacing disks at any of the chain auto-parts stores for cheap.
I use them all the time. However, even this is NOT NECESSARY, just a nice touch.
Sorry, that was corney. Sense of humor changes with 7 month old baby who likes singing.
Now, more serious matters--will my fluid still boil if I put in the ATE blue high temp stuff, brand new out of sealed metal container? I've had boiling issues before, but 1st time fluid was not fresh and second time it was on the shelf for a while (although sealed, and not ATE blue but Ford).
Would the 13" Big brakes from the GS help with this? I have them ready to mount.
Also, for 2 days at Pocano, from experience, will brand new pads get me by or should I bring the extra set as you say?
Thanks GS, I am buying the Nittos your rec. today. Decided not to mess with patches on the track, even though expensive.
if you buy it off the shelf and use it immediately (and seal was not broken in any way) chances are it will be okay. but, i wouldn't always guarrantee sealed = fresh. (i wonder if there are date codes on those things like beer??)
I would pack extra pads. Cheap insurance to avoid ruining part of a weekend because you need pads and didn't have them. Besides, you'll need pads before the next event, so why not buy them now?
Or do I really need a cooling scheme thru the side marker lights? I've seen that once on a serious looking GS at the drag strip, I gathered he was a road racer.
I'll pack the pads just in case on your advice--thanks.
Brake lines will help with pedal firmness. You should bleed the brakes before the event so that eliminates the near term moisture concern. FWIW, many of the Porsche and BMW clubs direct that the fluid be less than 30 days old or the car will flunk tech inspection. They'll take the driver's word the fluid is good. If people lie, it's their car they stuff into a wall.
For brake cooling air, I have openings in my front air damn with ducts and high temp aero-duct hose that run back to the center of the rotors. Here are some pics of my "Home Depot" special:
