9th Injector - Really need it?
Old Mar 9, 2005 | 12:30 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Default 9th Injector - Really need it?
Looking at installing a set of Edelbrock TPI tubes and the set availble doesn't have the hole for the 9th injector. So two choices are available. Discard the injector, or drill a hole. Drilling a hole is no big deal. But disabling the 9th injector might be a problem.
Anyone have experience with the later?
Opinions? I know everyone has one of those...
JRC
Old Mar 9, 2005 | 08:46 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
There is a delete kit from what i have read here. Can't remember who sells it.
Good luck Steve
Old Mar 9, 2005 | 09:12 AM
chucks88's Avatar
chucks88
Street and Performance carries such delete kits. I deleted mine when I went to the SuperRam. The car does now take a couple extra turns of the key to start when cold. It starts on one crank when it's warm. Reprogramming your chip may help but I'm not possitive about that one. Check with Jesse.
Old Mar 9, 2005 | 09:20 AM
LD85's Avatar
LD85
The newer bin file 88 or 89 allows for a pump shot at the start to eliminate the 9th inj.
dgoodhue's Avatar
dgoodhue
If you have an automatic, you can just use 89 auto chip.
Old Mar 9, 2005 | 10:48 AM
GlennS87's Avatar
GlennS87
I would try the ARAP bin. It was supposedly the most aggressive chip (I've seen this posted on different forums over the years) that GM produced for the early MAF cars. I had my tuner user the ARAP bin as the starting point for my custom chip for this reason.
Old Mar 9, 2005 | 10:52 AM
scorp508's Avatar
scorp508
Tunercat has added the ability to edit the cold start values WITHOUT a 9th injector to the $32b code that 87/88 use. I have not checked $32 fo '86, but I can only imagine that they could add it easily if it isn't there yet.
So, yes, assuming TC can pop the fields in there for you if they haven't already then disabling the 9th will cause a couple extra turns to start when cold (it isn't much), but it your chip can be modified to help eliminate that delay.
Anyone using ARAP just keep in mind that was for Automatics. There was a 6-speed version as well, but I forget the BCC for it at the moment.
Old Mar 9, 2005 | 11:02 AM
dgoodhue's Avatar
dgoodhue
Knowing what I know now, I personally wouldn't use 86 code ($32 mask). Mostly the 87/88 is just an update and it has an easier time connecting to scan tool software.
Old Mar 9, 2005 | 12:16 PM
Jim85IROC's Avatar
Jim85IROC
I have some fuel rail caps available. If you're interrested, feel free to email me at jim85iroc at yahoo dot com.
Old Mar 9, 2005 | 09:29 PM
JrRifleCoach
Originally Posted by AGENT 86
There is a delete kit from what i have read here. Can't remember who sells it. Good luck Steve
Thanks Dan, The weather here doesn't really require alot of "choke" If it does, "Rose" stays warm and comfy.
You've got mail!
Since I've started tuning my chip, and without going into all the details here, can one load the $32b into a 27c128? I have an 86-A4
Originally Posted by scorp508
Tunercat has added the ability to edit the cold start values WITHOUT a 9th injector to the $32b code that 87/88 use. I have not checked $32 for '86, but I can only imagine that they could add it easily if it isn't there yet. So, yes, assuming TC can pop the fields in there for you if they haven't already then disabling the 9th will cause a couple extra turns to start when cold (it isn't much), but it your chip can be modified to help eliminate that delay.
I need to check out TC
[QUOTE=GlennS87]I would try the ARAP bin. It was supposedly the most aggressive chip (I've seen this posted on different forums over the years) that GM produced for the early MAF cars. I had my tuner user the ARAP bin as the starting point for my custom chip for this reason.
This is most interesting. I have a copy of ARAP from the DIY FTP site. I'll give it a try. Thanks
Thats another option, Anyone have a 89 auto bin file?
Now I gotta try this. Anyone have a 89 auto bin file?
Thanks for the tip!
Old Mar 9, 2005 | 10:48 PM
dgoodhue's Avatar
dgoodhue
Yes you can use a $32b, you just need to start off with a 87 or 88 Bin. I personally use 89 to start with, but for 4+3 you really need to use 87/88. Their are some advantage in the $32b, in that the fuel table is a little more adjustable. 89 has disadvantages as well. ARAP bin is suposedly the magazine .bin, it didn't come in any factory vehicle.
Old Mar 10, 2005 | 01:24 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Jim, what thread size are they? Is it a plug that threads directly into the fuel rail, or actually a cap that goes on the stock fitting?
I recall seeing some plugs with orings, which seems to be the simplest method.
To 9th Injector - Really need it?
