I just noticed a blinking SYS in the digital gauge of my 96 LT1 Coupe. The service manual talks about a doing a diagnostic through the data link connector (DLC). The manual goes on and on about grounding certain terminals in the DLC. It's all greek to me. Does anyone have an easy way to figure out why the SYS error is appearing?
I don't have time in my work schedule nor do we have an AutoZone in my area.
The car hasn't been started in almost a month so I'm hoping the error occured because of a low battery condition. Now I just need to see the codes to confirm this and clear it.
I had let the car warm up to temp for about 30 minutes shut it down.
I just went out and started it up again and sure enough the code is gone. A low battery condition must have been it. I think I need a battery tender because the car sits more than it is driven.
Since when? All cars batteries are charged by the engine operating.
Today's alternators can't handle charging a weak battery.
For example, when my battery went dead, I let it idle for over two hours, shut it off and an hour later, the car wouldn't start, battery was weak still.
Best way is to fully charge the battery before attempting to start. It will make it easier on the alternator. My buddy who is a tech confirmed this.
Like you said, get a battery tender and never worry again.
I agree! In doubt, turn ignition off and use your voltmeter. It should be about 12v measured directly at the battery poles. Start the engine and let it idle, the voltage should increase to about 14v. It should be about 14v when you drive too. If this happens the battery is charged to some extent.
The battery is damaged when it becomes discharged. A damaged battery cannot be "repaired" by charging it. This is why it should be charged on a regular basis. The other thing to remember is that the alternator in cars generally charge the batteries to about 80% of their capacity.
It might be a good idea to have a shop perform a battery load test to see if the battey is capable of still providing adequate starting power. Letting the charge drop to where it may not be able to start the car can kill a battery in no time.
You can find 12v battery charges reasonably priced and the ones that provide 6 to 12amp output will last forever. That and a tender are two thing a Corvette owner should always have.
I get it now, thanks. The battery in the car is a Optima Red Top and it has worked great for several years. I specifically bought it for it's long shelf life.
Now where to get a Battery Tender at a good price.
