Technique For Brake Fluid Change
Old Mar 11, 2005 | 11:31 PM
KAZ2's Avatar
KAZ2
Default Technique For Brake Fluid Change
I want to replace the brake fluid in my 87 and from what I've read the "gravity" method sounds good. I don't mind if it takes more time, I have good brakes and want new fluid without stressing out my master cylinder etc. My question is do you open up the bleeder valves one at the time in the correct bleeding order. Will things work out as long as I keep pouring in the new fluid on top? Any experience/cautions or steps that you know work would be appreciated. Regards
Old Mar 11, 2005 | 11:39 PM
C4396roadster's Avatar
C4396roadster
get a mityvac or have a friend pump the pedal while you crack the bleeder is good too. use a hose could get messy...
I use the mityvac myself for easy one man operation first siphon out fluid from the master and fill with fresh fluid and start from there.
Old Mar 11, 2005 | 11:45 PM
TrackDayLT4's Avatar
TrackDayLT4
I just use a mity vac hand pump. You can get them at most autoparts stores.
Just fill the master cylinder reservoir, hook the pump to the bleeder valve, pump a little vacuum, open the valve and let the fluid flow. As the flow slows down, pump a little more.
Close the valve, and check the fluid level regularly so you don't drain it down too far and pull air into the top of the system.
It is really easy, puts no stress on the master cylinder and it only takes me about 30 minutes completely flush the system.
Cheers,
Lawrence
Old Mar 12, 2005 | 12:28 AM
KAZ2's Avatar
KAZ2
Thanks very much, I'll get a mity vac tomorrow. I like the idea of using it to establish a vacuum and being able to do it with one person. Regards
Old Mar 12, 2005 | 01:29 AM
skeet's Avatar
skeet
Is there any special bleeding order? I thought there was because of the ABS module?
Old Mar 12, 2005 | 05:01 AM
Dan Parker '96's Avatar
Dan Parker '96
The best "one man" method is to hit AutoZone (or equivalent) and snag any no-name "speed bleeder" set.
If your caliper fittings aren't corroded beyond belief then the "speed bleeders" will allow a quick and confident bleed of the hydraulic system. No bitches or 5 foot PVC tubing needed.
Old Mar 12, 2005 | 08:41 AM
DRAKEFAMILY2's Avatar
DRAKEFAMILY2
The order i use is start at the farthest wheel from master cylinder and work toward closest.
Old Mar 12, 2005 | 09:39 AM
c4cruiser's Avatar
c4cruiser
The service manual shows a different bleeding procedure. The sequence for my 87 is RF, RR, LR, LF
But the sequence shown for my 92 is RR, LR, RF, LF. Go figure.
Speed Bleeders are a great way to bleed brakes at the track , but don't scrimp on them. I had a set of Russell bleeders and they all leaked. I went with the "Speed Bleeder" brand and have had no problems with them.
Old Mar 12, 2005 | 07:08 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
I got speed bleeders out of the "Help" section of the auto parts store. There are made by motor-mite? I had two leaky ones... does anyone know what causes them to leak? I just find it odd that something so simple can leak!!!
Oh... and another vote for the Mity Vac. I use the Mity Vac with the speed bleeders becuase I am sorta obsessive-compulsive
Old Mar 12, 2005 | 07:13 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
I wish I could get a few of 'those' to help me bleed my brakes.
Old Mar 12, 2005 | 07:20 PM
JAKE's Avatar
JAKE
The GM 1986 Corvette Shop Manual (page 5-7) shows, left rear, right rear, left front, right front.
My son and I just changed over the fluid a couple of days ago using the manual (pump the pedal) procedure and following the above sequence. Pedal is noticably higher now and firmer.
I was trying to track down the cause of an Anti-Lock dash light and wanted to eliminate the fluid as a possible cause. Still have the light though.
But I agree, all the different sequences, Go Figure.
Jake
To Technique For Brake Fluid Change
