Auto Trans problems..help
Old Mar 12, 2005 | 06:14 PM
sniperdiver37's Avatar
sniperdiver37
Default Auto Trans problems..help
Took my 88 TPI auto out for a in town drive after a long winters sleep. after she got hot 200 in stop and go traffic I started feeling a shutter from 1st to 2nd.manual shift, no problem, in D it shutters.
anyody have this problem?
It's a given I'll pull the pan and change the fluid and filter but the fluid is full and no sign of being burnt.64k on the car unknown on the fluid.
can I add an additive that will help out?
Thanks, Jeff
Old Mar 12, 2005 | 06:20 PM
1986coupe's Avatar
1986coupe
Default Auto Trans
Avoid additives. These are cheap Fixes that usually cause other problems. Most of them end up getting investigated by the Federal Trade Commission.
Get a good transmission mechanic to advise you based on the information that you can provide.
Old Mar 12, 2005 | 06:24 PM
sniperdiver37
After reading what happened to BMF42 and all the good times I've had over the years with tranny shops I trust them about as much as crack heads and tweekers.
Old Mar 12, 2005 | 07:56 PM
Pete K's Avatar
Pete K
What you are describing sounds like torque converter shudder. Change fluid and filter. If this doesn't help it could be a lock up solenoid or bad torque converter.
To Auto Trans problems..help
