It's for sure the ECM is bad, need suggestions, every day driver, not raced. best bang for my $$$. What do you suggest? Is the change over easy, and whats the best procedure for accomplishing it.
A couple of years ago I replaced mine. Cost $100 for a rebuilt unit, plus the core charge that was refunded upon sending back the old unit. It's a very easy job, perhaps 15 minutes or less. Just disconnect the old unit (after disconnecting the battery), swap it out, and hook up the new unit. Oh yes, don't forget to unscrew the little door on the bottom and retrieve your mem-cal. That's the memory that needs to be transferred to the new unit.
Listen to me on this one.. Get a acdelco rebuilt one. The swap is easy. Marcho polo has a tech tip on the swap. I just took back my third A1 Cardon POS.
Bad news Rich, guess who rebuilds ECMs for AC Delco........you got it, A1 Cardon
Most good recyclers can look up what unit will cross reference. I used a unit from a pontiac 6000 once ( I Don't remember what year.) in an 85 corvette. Out side looked exactly the same changed the chips and I was off and running. Cost me $50.00. The car is still running and this was six years ago. This option will be harder or maybe not work at all. On cars that the chip cannot be changed. Got to love those L-98's
Mike
Quick question now that I have installed a bypass switch to the fan when I replace the ECM can I leave it in place this would be a distinct advantage given the hot climate here in Florida.
What symtoms did you have that lead to the bad ecm diagnosis? My 85 started acting up on the way home from work. It appears to be an ignition problem but none of the usuall items ie spark plugs, wires, cap rotor, coil or ignition module are the problem.
As I understand it it's the PROM that makes the difference.
Mine is a 7165 and any car that uses the same one, like many of the 'F' bodies (Camaros, Trans Ams, etc.) will work.
The 85 has a different ECM though; it's, I guess you'd call it, first generation with a slower baud rate.
A few years ago when I had to replace mine, I got it at O'Reilly's auto parts for $100, remanufactured, which folks claim is different from "re-built".
Who knows, but it's still going strong.
If I have to replace it again , I'll be heading to the wrecking yard.
Like the guy in the fat wife commercial said, "Youbetcha!"
The Mr. Goodwrench has a shop next to my office, when the cooling problem occurred, we swapped relays to the ac and no problem, than the fan quit working on the max ac setting, and upon checking there was no signal coming from ECM to the relay. He told some of my other symtoms may be corrected after replacement.
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
Since your switch is external to the ECM it shouldn't cause the new one any problems. The early C4 ECM is basically a small computer motherboard in a metal container. On your 85 it should be under the passenger side dash, hidden by the lower hush panel. Takes about 10 minutes to remove.
As MTVette stated, BE SURE to remove the MEMCAL chip from your old unit before giving the core up. It is a PROM (Programable Read Only Memory) chip in a light blue (usually) plastic housing. The MEMCAL is specific to your vehicle year and transmission type. Treat it like the delicate electronic component it is. Don't drop it or touch any leads.
NAPA had rebuilt AC-Delco units for about $115. About 6 months after I bought my 88 I had my ECM replaced with a "Genuine GM" unit at the dealer. After 14 months it went bad again. The second time, I went to NAPA, and installed their rebuilt unit myself. Haven't had a bit of problem in over 5 years.
Oh yeah, the dealer charged me for an hours labor at $90/hr to do a job that takes 15 minutes. Never going to a dealer again.
