Motor Mounts
Old Mar 12, 2005 | 12:16 PM
elkabong's Avatar
elkabong
Default Motor Mounts
Anybody out there have any recommendations on motor mounts for my 84 with a 383? I figure I should replace the originals during my motor swap.
Old Mar 12, 2005 | 02:28 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
believe it or not, i couldn't find any performance replacement motor mounts for my '87. i tried Energy Suspension (and a bunch of others) and couldn't get my hands on the urethane mounts. not sure if the '84 uses the same mounts or not.
so i went to GM and bought OEM.
Old Mar 12, 2005 | 02:36 PM
bogus's Avatar
bogus
I think GM used the same, hard rubber mounts from the mid-60s through to the late 80s.
You might find them in a racing supply house, but even then, I don't think you would want them.
They would transfer all sorts of nasties into the chassis...
Old Mar 12, 2005 | 02:52 PM
scorp508's Avatar
scorp508
There are no aftermarket "upgraded" engine mounts for C4s. At least in 5 years of ownership I've never seen one. The stock GM type units are all you can get.
Old Mar 12, 2005 | 04:21 PM
CFI-EFI's Avatar
CFI-EFI
I don't know when the change came, but C4s do not use the same mounts as back in the 60's. The change over must have come in the late 70's to early 80's. It might have come with the C4. I haven't seen any "good" mounts for a C4, either.
RACE ON!!!
Old Mar 12, 2005 | 06:15 PM
bogus's Avatar
bogus
They changed again with the LT1... The newer style were easier to change under the car.
Old Mar 12, 2005 | 06:33 PM
JAKE's Avatar
JAKE
I came across some aftermarkey mm in one of my catalogs, but didn't pay a whole lot of attention to them though. I'll see if I can find them again; if I do I'll post.
I do know that some of the more rigid mounts transfer a lot of vibration into the car; vibrations that the stock mounts absorb.
Jake
Old Mar 12, 2005 | 06:36 PM
JAKE's Avatar
JAKE
Also remember years back when I pulled a 350 TPI from my new 86 Trans Am and installed a 468 BB, I used the same motor and frame mounts. Nothing like a BB in a 'F' body!!
The T/A had holes already factory drilled in the frame. All I had to do was move the frame mounts to the forward most set of holes and the engine dropped in like it was always meant to be there.
So, my thinking is that if the stock ones can handle a 468 BB, . . .
Jake
Old Mar 13, 2005 | 10:44 AM
elkabong's Avatar
elkabong
Well I guess I will get a new set from the dealer.
Old Mar 13, 2005 | 04:19 PM
Ramanstud's Avatar
Ramanstud
problem with the stock (NOS) rubber mounts is that with 470+ ft-lbs of torque the motor twists so much on launching that it bows my stock 84 hood 1/4 - 1/2"!!! I'd love poly even with the vibration transmissions just to keep things planted. Granted, the superram and lower slung `84 style hood (as opposed to 85 up) might be an issue, I just worry about the stresses on the hood.
To Motor Mounts
