Opti Upgrade Part #'s
Old Mar 14, 2005 | 09:40 AM
STL94LT1's Avatar
STL94LT1
Default Opti Upgrade Part #'s
I'm getting ready to install a new camshaft. While I'm at it, I've decided to upgrade my opti and timing chain. Does anyone have the part #'s for the 95/96 opti upgrade.
Timing cover (95)
Wire harness
OptiSpark
Vacuum line
Any other parts needed for the upgrade
Cloyes double roller timing chain.
Balancer hub, I know I don't need it for the upgrade, just want to replace the current.
Old Mar 14, 2005 | 10:03 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
I am in this process too. I'm curious, is the vaccum line you listed just the extra one for the new opti?
The summit part number for the correct Cloyes is: CLO-9-3145 I just picked one up this last week. Looks like a nice part.
I also sourced the newer style timing cover off ebay for 15 bucks.
Also would you need a new oil pan gasket and timing cover gasket?
Hope that helps a little. Other than that I think you have everything.
Old Mar 14, 2005 | 10:06 AM
Strick's Avatar
Strick
How about upgrading your coolant pump? Go with a Meziere heavy duty electric pump and the timiing chain upgrade will be easier with out the gear driven pump shaft. And you'll eliminate one possible oil leak at that seal, and, theoretically, gain a few extra ponies.
Old Mar 14, 2005 | 11:11 AM
STL94LT1's Avatar
STL94LT1
Already have the Meziere, and a new oil pan gasket. But, will need to get a timing cover gasket.
Old Mar 14, 2005 | 11:51 AM
sothpaw2's Avatar
sothpaw2
I don't remember the #'s, but if you go on gmpartsdirect and go after the extreme duty timing chain, the opti and cover, etc. part #'s are given w/ the listing for the chain kit.
So you went with upgrading the vette--didn't get the Buick GN? too bad.
Cam from Pete @ CNC? What will it be?
Old Mar 14, 2005 | 12:25 PM
STL94LT1's Avatar
STL94LT1
Yeah, i decided not to get the GN. I just don't need three high performance vehicles, already spend enough money on the Vette and Lightning.
Yes, the cam is a Comp Cams custom gring from Pete.
Old Mar 14, 2005 | 12:52 PM
tjwong's Avatar
tjwong
Timing cover (95)
Wire harness
OptiSpark
Vacuum line
You can just replace it with the stock LT1 hub for a 93 to 95 LT1. Don't get one for a 96 because they used a crank sensor which makes the hub about .100" shorter in length. As long as th Cloyes crank sprocket is the same thickness as the stock LT1 sprocket the hub and pulley alignment will be ok.
Old Mar 16, 2005 | 12:15 PM
STL94LT1's Avatar
STL94LT1
Default ^^^
Anyone with part #'s?
Old Mar 16, 2005 | 12:39 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Get ahold of Chris at Superior Chevrolet.
My part numbers were, Opti 1104032, harness 12130319, harness 12558921. These were on my reciept, Already had the cover. Hope some of this helps, but the SUperior Chevrolet website should have it all sa stated above.
Old Mar 16, 2005 | 01:11 PM
STL94LT1's Avatar
STL94LT1
Thank You Steve.
Old Mar 16, 2005 | 04:14 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Required reading for optispark swaps
Old Mar 16, 2005 | 04:20 PM
STL94LT1's Avatar
STL94LT1
Thanks Ramrod92, just what I was looking for.
Old Mar 16, 2005 | 08:18 PM
Red Rocket's Avatar
Red Rocket
Down the road you might look at the Delteq ignition set up as well. Picked up 20+HP 6200-6500 RPM with this upgrade. Eliminated the MSD also.
To Opti Upgrade Part #'s
