Stutters
Old Mar 16, 2005 | 08:06 PM
blacker's Avatar
blacker
Default Stutters
I just got my 70,000 mile 89' coupe out of the shop having installed a new mass airflow sensor and a new ecm. The car runs great except at 2400 rpm the engine stutters briefly. This only happens at cruising speed in second or fourth gear. I can literally hold it at 2300, let it creep up to 2400 and there is a slight bump. Everything is fine from there. It accelerates very well from that point on. I have gotten no check engine light and seen no decrease in performance. Has anyone else experienced this?
Old Mar 17, 2005 | 09:31 AM
rick lambert's Avatar
rick lambert
I read a post once about a similar problem-ended up being the oil temp
sensor, seems like this little guy can cause a stumble, but won't throw a code.
