Slave Valve Questions?
doing it myself. The Chevy dealer charged me $163.82 for the SLAVE,
$172.00 for 2 hrs. labor. TOTAL =$335.82. QUESTIONS are: Is it worth
doing myself? Is it wise to purchase from a normal PARTS SHOP instead
of the dealer? Would the SLAVE VALVE be BRAND NEW or REBUILT (does
it matter)? IS IT ABSOLUTELY NECESSARY TO BLEED SLAVE BEFORE
INSTALLING IT INTO HOUSING? I don't think the mechanic bled the SLAVE
prior to install the last time it was done. What will happen if it is not bled
before install? Finally, if leaking fluid is inside HOUSING, does it have to be
removed? What happens if it is not REMOVED? THANKS SO MUCH!
Before buying the new slave I would recommend that you remove the old one first and just check that the lock ring is in place correctly. My bet is that is where your problem is. Heck, it can't hurt and may just save you a c note. I had/have a brand new one out of the box that was not set properly.
I hope this helps.
BTW: what year car do you have??
I hope this helps.
