Not sure what the exact reason for the different sizes on the C5, but it does give the illusion that the car is lower in the front.
On an 18x9.5 rim you can use 275/35 or 285/35. Personally I would go with the 285/35. Another option is to use Z06 wheels, then you can use 295/35 out back like I did.
what about the offsets ?will that fit an 89 with 56mm offset. z01 have different offset, how does this effect fitment.
