Front Ball Joint Removal
Old Mar 17, 2005 | 09:34 PM
mothersworry's Avatar
mothersworry
Default Front Ball Joint Removal
How do I remove the upper and lower front ball joints to replace them?
Uppers look like I may have to drill and the lowers I have no Idea. BTW my car is a 92.
Old Mar 17, 2005 | 09:40 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
The uppers need to be drilled out.
The lowers needs to be pressed out.
My experience
The upper I got the ball joints out but had a hard time with the remaining studs.
The lower I broke a ball joint remover.
Then: Sent them in to a shop $150 latter they were done (Also and the bushing replaced)
Old Mar 17, 2005 | 10:36 PM
whfla's Avatar
whfla
yes the uppers must be drilled out , and the lowers need to be pressed out...with the correct tools and no unforseen problems on a difficulty scale it rates about a 6 ....good luck !!
To Front Ball Joint Removal
