Cam Recommendations for 355 LT4..
Old Mar 17, 2005 | 11:11 PM
thmupr's Avatar
thmupr
Default Cam Recommendations for 355 LT4..
Anyone have some good data on cams for LT4 350's? I was going to run a hot cam, but I think I wasnt something different. Looking for good mid range power, not loosing any low end, and keeping a decent idle. My heads will probably be ported by TJ cylinder heads, and my compression ratio is just under 11:1. let me know what you guys think.. Thanks in advance..
Chris
Old Mar 17, 2005 | 11:16 PM
fa63's Avatar
fa63
Once you get some head flow numbers for your heads, take those numbers and get a custom camshaft made for your application. It might cost a little more, but it is well worth it at the end.
Old Mar 18, 2005 | 12:30 AM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
The hotcam does OK. There are alot of other grinds that work just as well. I'm sure NP will be in here shortly to extoll the virtues of the HC. I went with the HC because thats all I could afford. I really wanted something a bit more aggressive but couldnt swing the extra $$$ to upgrade the rest of the valvetrain. If I had my choice it would be something in the I224 E230 range WITH .550 lift numbers. Maybe even 230 236.
Old Mar 18, 2005 | 04:03 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I went with the comp cams hyd roller cam for nitrous, 1.6 rocker shafts. Not for the low buck guy.You have to get sucked in like I did .
After it was built the last thing that was checked was intake clearence and it was off .375 adjustable guide plates would not work ,
to much off set.
AFR heads $2500.00 shaft rockers $1018.00.
Chose wisely you could end up like me.
To much money invested to change now.
I just hope it runs like I want.
Old Mar 18, 2005 | 06:45 AM
thmupr's Avatar
thmupr
Does the hot cam maintain a fairky smooth idle?
Old Mar 18, 2005 | 08:58 AM
99svrcpe's Avatar
99svrcpe
Yes...with the idle bumper up to 900.
Old Mar 18, 2005 | 10:18 AM
boulderlt4's Avatar
boulderlt4
Hotcam is too mild, IMO! Not enough bang for the buck.
I opted for a little more aggressive cam. Smooth idle, great sound and power.
Hot Cam vs. Custom Cam Discussion
http://forums.corvetteforum.com/showthread.php?t=892304
The results of custom cam
http://forums.corvetteforum.com/showthread.php?t=901626
Good Luck!
Seems a lot of people here have had great results with the hot cam.
Old Mar 19, 2005 | 02:31 PM
thmupr's Avatar
thmupr
boulderLT4,
How smooth does your Vette run in traffic with that cam? Any problems in hot weather? Sounds like it might be the way to go, ..
Chris
To Cam Recommendations for 355 LT4..
