Replacing F-45 Shocks:......Advice Needed
Old Mar 18, 2005 | 05:58 AM
GS348's Avatar
GS348
Default Replacing F-45 Shocks:......Advice Needed
I am replacing the shocks in my GS and would like to switch to Bilsteins if at all possible. Is this gping to be a pain by bypassing the adjustable F-45's? I'm sure that this has been done but I want to check out my options. Any advice?
Old Mar 18, 2005 | 06:46 AM
Solo2GS's Avatar
Solo2GS
St. Jude Donor '07
Getting ready to do it myself with a set of adjustables. I have seen it done by many others and it is not a pain at all other than what changing out a set of shocks is.
Old Mar 18, 2005 | 08:16 AM
runner140*'s Avatar
runner140*
Default Its an easy job....
No problem to go from electronic to standard. And its an easy install.
Old Mar 18, 2005 | 01:44 PM
GS348's Avatar
GS348
Default Sounds Good So Far, but......
what about the switch which adjusts the shocks, do you simply put a block off plate from the non F-45 cars? Or I guess it would be a pretty trick place to put my new nitrous switches................hmmmmm
Old Mar 18, 2005 | 06:28 PM
96GS#007's Avatar
96GS#007
Here' this should help. I wrote this up when I tossed my F45 shocks...
http://www.grandsportregistry.com/te...placements.htm
I left the center switch.
Old Mar 20, 2005 | 07:34 AM
GS348's Avatar
GS348
Thanks..........I should have checked the registry sooner. It's time to update both my brother's and my GS's.
Old Apr 21, 2005 | 12:13 PM
GS348's Avatar
GS348
Default Which Year?
Is there a specific year which is better than others. I've seen someone switch to an early 90's ZR-1 who switched to the Bilsteins. Shouldn't 95's be better or is their some riggin' thats going to be involved either way I happen to do this successfully?
To Replacing F-45 Shocks:......Advice Needed
