Rear Camber question
Old Mar 18, 2005 | 06:43 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Default Rear Camber question
OK I ask this only because I want to know exactly what to do before I do it. My drivers side rear wheel has about a 3-5 deg positive camber and I know where the adjustment is on the diff. Loosen bolt and click it in. What direction to move the adjuster?Clockwise or Counterclockwise?
I am guessing Counter clockwise. And what is the torque on that bolt?
Thanx
Old Mar 18, 2005 | 08:53 PM
tempest's Avatar
tempest
don't think about clockwise/counterclockwise - it is easier to think along the following lines:
if you move the cam so that the control arm pivot moves towards the outside of the car, then you are making camber more negative.
(footnote: postitive camber is where, when you look at the car from behind, the top of the tire sticks out more than the bottom - that's what you're seeing, right?)
Old Mar 18, 2005 | 08:57 PM
tempest's Avatar
tempest
forgot about the torque - it's 253 N-m (186 lb-ft) on my 92. should be the same as your 93.
Old Mar 18, 2005 | 09:02 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Perfect info here!!! Right on.
Old Mar 18, 2005 | 09:05 PM
edsalinas's Avatar
edsalinas
I agree, just make it real tight and use some blue loctite on the threads down where the nut will end up...
Old Mar 18, 2005 | 09:19 PM
JAKE's Avatar
JAKE
Another little trick: Before you break loose the nut and make any adjustment, scribe a mark with something that'll stand out (I use red fingernail polish).
That way you can visually see the original location. After you make the adjustment and are happy with the result, you can scratch off the original mark and scribe on a new one.
That won't tell you anything about degrees but it'll give you a point of reference.
To get an idea of the number of degrees involved I use a magnetic angle Locator I found at ACE Hardware. Not in the same league as what the alignment shops can measure, but it's good enough for government work.
The mark also allows you to be able to tell if the setting has moved.
I fooled with my rear (No, the other one) a couple of days ago. The passenger side was 3 degrees positive; I changed it to zero.
I had a slight pull to the right and thought it was something with the front but turns out to be the rear.
MAN WHAT A DIFFERENCE.
Jake
Old Mar 19, 2005 | 01:49 AM
olman's Avatar
olman
A couple sheets of wax paper between the tires and floor will let the tires slide around for checking your adjustments.
Old Mar 19, 2005 | 11:29 AM
JAKE's Avatar
JAKE
I can't see how that will work.
I can't get to the rear adjusters with the car on the ground and, for the front, my socket can't access the nuts unless the car's jacked up to raise the nuts above the upper 'A' arm.
Jake
To Rear Camber question
