Replaced injectors $#$#^!!
Old Mar 18, 2005 | 08:55 PM
vettish 91's Avatar
vettish 91
Default Replaced injectors $#$#^!!
I finally replaced all fuel injectors today. Only took about 3 hrs. Most time consuming was removing and putting surrounding parts back together. I couldn't wait to start the car...only thing is, is that the car wont stay running, service engine light comes on, try to put the car in drive and it stalls. Retraced all the connections, vacuum hoses etc. everything appears to be ok.. does anyone have any ideas. After changing injectors does something have to be reset.HELP
Old Mar 18, 2005 | 09:11 PM
Hawaiian Punch's Avatar
Hawaiian Punch
what injectors you have in there? size wise?
Old Mar 18, 2005 | 09:13 PM
ittlfly's Avatar
ittlfly
Put a fuel pressure guage on it to be sure all is well with the fuel pressure. Did you replace the injectors with OEM or ?? Some folks have some problems with certain types.
Old Mar 18, 2005 | 09:14 PM
vettish 91's Avatar
vettish 91
Bosch/Ford - 22lb
TPI 305/350
BRAND NEW Sets
0280150561-D9B
Fitments:
1989-92 Camaro TPI 305
1985-92 Camaro TPI 350
1985-91 Corvette L98/LT1 350
bought from five-o-motorsport in CAl.
Old Mar 18, 2005 | 09:16 PM
scorp508's Avatar
scorp508
If the SES light is on then pull the codes for us. That'll most likely help.
Old Mar 18, 2005 | 09:19 PM
ittlfly's Avatar
ittlfly
Damn good point!
Old Mar 18, 2005 | 09:22 PM
vettish 91's Avatar
vettish 91
the SES light comes on but there is no code (flashing)
Hawaiian Punch
this might sound very stupid, but try opening up your gas cap, mine did the same thing ince before and a buddy of mine told me to do that, I didnt listen to him cause I though he was stupid, untill I finaly did and sure enough, it started right up, go figure.
Old Mar 18, 2005 | 09:30 PM
scorp508's Avatar
scorp508
You shouldn't HAVE to reset anything, but removing the battery cable for 1 minute is always a good idea. I'd definitely go and make sure that you're FP builds up with the key in the "on" position to start with.
Old Mar 19, 2005 | 01:22 AM
vettish 91's Avatar
vettish 91
Just got home after a few drinks, pulled the fuel cap, took off the bettery cable and the car still runs like crap. Maybe i should have just left the old bearly functioning injectors!! Any way tommorrows another day, I guess most of it will be spent trying to figure out whats going on....Thanks for all your suggestions...
Old Mar 19, 2005 | 01:33 AM
Insane1's Avatar
Insane1
It will not flash a code unless you put it in diagnostic mode. If it doesn't flash a code with the car not running then flash it while the car is running or go buy a code reader.
Old Mar 19, 2005 | 02:52 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Did ya try raising and lowering the drivers window?
Old Mar 19, 2005 | 03:35 AM
85 500 horse's Avatar
85 500 horse
You got it wrong. You must lower your windows and leave them lowered. If you raise them again, you create an error message and have to repeat the entire cycle.
Old Mar 19, 2005 | 02:19 PM
vettish 91's Avatar
vettish 91
Car finally running GREAT,injectors ticking away (haven't heard that music in quite some time) like a new 1991 vette. I took the plenum off, changed the gaskets, replaced all the vacuum hoses and the engine started right up and continued running smooth. I took the car down to our local street where you can get the speed upto 120. What a difference in performance with the new injectors..Thanks to all who helped. Frank
Old Mar 19, 2005 | 03:04 PM
Hawaiian Punch
yea yea laugh it up fuzz ball.
Old Mar 19, 2005 | 04:29 PM
scorp508's Avatar
scorp508
Nice! 120 in an L98, that must be a long street.
To Replaced injectors $#$#^!!
