coolant temperature switch....replacement values???
there are two temp sensor 89 L98
1) located between 7&8 which is spade type
what is it's function? gm part #?
2) located between 1 & 5 which pin type
what is it's function? gm Part #?
want to replace one of the sensor to tell ECM, for fans to come sooner EX on @ 210*F off @ 195*F.. what is the gm part# for this sensor.
ecklers has one... BUT there should be a part that is available from auto parts store..just need the numbers..does any one know that could help me with this part?
If your 89 is like my 86, then the sensor between 6 & 8 is for the display on the dash, the one between 1 & 3 is for the aux fan in front of the radiator, and the ones in the manifold underneath the throttle body tell the ECU what the temps are.
On mine, I was able to have my chip reburned to change when the fans come on. I tried a lower-temp sensor, but it didn't work for me (wrong year - it was designed for 84/85).
[RICHR]
so you can not replace #1 or # 2 with different lower on /off switch? kinda like tricked the ecm into thinking that it should turn fans on @ 235*F
BTW: thanks for the part numbers CFI-EFI
If you change #1 to a different value it will only change the gauge reading. It may end up showing the temp you want it to when the fan switches on. It won't change the "ON" temp, but the gauge will read differently when "ON" occurs.
You can change #2 to alter the "ON" point of the axillary fan.
Number 3 tells "The ECM the engine for ALL engine functions". If you change the value of #3, you will change what the ECM sees for all it's functions. The engine would run terribly.
If changing or reprogramming the prom for the on-off temps you want, is not something you want to do, you can tie the main fan to the aux fan, with a cooler switch. Or you can simply add a manual switch for the main fan.
Okay here is what I did with my fans on my 89
I installed a 195 degree on and 180 degree off fan switch where the aux fan switch is on the drivers side cylinder head between cyl 1&3. I connected it to the green-white wire on the aux fan relay then I ran another wire to the main fan relay and connected it to the green white wire on it. Now both fans come on at 195 and turn off at 180. The main fan still runs when the air conditioning is on by being controlled by the ECM. I feel a lot more comfortable by being able to control the fans at lower temps and having the engine run cooler in town. Just my 2 cents worth.
I did this for my aux fan, using a relay from the junkyard and wiring a switch under the dash by the ALDL connector. Just be careful where you route the wires and mount the relay; the driver's headlight well looks like PLENTY of usable space, but believe me - the light needs it ALL. Had all my wiring nicely in place, turned on the lights, and ripped it all out... RGH!
[RICHR]
this is what i want to do....i did manual switch.. PITA...what was the part # of the 195* F switch?
[RICHR]
There was no need for an additional relay. Just hook the switch up to provide an additional ground path for the primary circuit of the stock relay. Also, if you lose track of the temps, the ECM and A/C will STILL kick the fan in when called for. It is as simple as a switch and two lengths of wire. You did WAAAAAY too much work.
RACE ON!!!
just add the switch...did this.. maybe the trick is to have the secondary fan come on early by changing that 1-3 temp switch and still use manual switch if thing get hot......
thanks
I bought the switch from either Mid America or Corvette Central I can't remember who. I forgot to mention that you will have to have a thermostat that is lower than the off temp of the fan switch or the fans won't turn off. I have a 160 t-stat. I can let my car sit in the driveway running and and it will heat up to 195, then the fans kick on and it will cool down to 180 the fans turn off and it starts the process over again. Since I have installed this switch I have never seen the temp over 200. I also keep the space between the air conditioning condensor and the radiator clean.
Try MAM, Eckler's or Summit for the lower temp aux fan switch.
I put a wiring method in C4 Tech Tips on hooking up the aux fan switch to drive both fan relays. You can get the clip on connectors from Radio Shack so that no soldering is necessary and you can hide everything inside the large wiring harness.
wouldn't ya know it, search function fails me EVERY time
sure would like to read it ,,,,, if it were working
Actually, I just didn't post all the details... my car came without the aux fan, so I bought one off eBay fully intending to make it a manual-only one. It was recommended that I use a relay so as not to have the full wattage (amperage? it's late) running to the (light-duty) switch under the dash. IIRC, the factory-installed aux fan has its own relay already that's separate from the main fan. Mine just mimics that.
[RICHR]
