Fuel Pump Jumper
Old Mar 19, 2005 | 04:43 PM
WNDOPDLR's Avatar
WNDOPDLR
Default Fuel Pump Jumper
I am finishing up replacing my TPI setup on an 88 L98 with a MR. I have replaced some of my fuel lines and added a new fuel filter during the project. I have all of my fuel lines, fuel filter and fuel rails to fill and check for leaks.
I am running into the 2 second cut out on the computer and it seems to be taking forever to get the system charged and up to preassure.
Is there any way to jump around the computer and run the fuel pump until the system is charged?
Thanks everybody for your help.
Old Mar 19, 2005 | 04:52 PM
B84RADR's Avatar
B84RADR
I believe you can run 12v to a pin on your ALDL port, I can't remember which one. I'll try to find out.
Old Mar 19, 2005 | 04:53 PM
CFI-EFI's Avatar
CFI-EFI
Power up terminal "G" in your ALDL with 12 volts. The pump will run as long as the voltage is applied.
RACE ON!!!
Old Mar 19, 2005 | 06:26 PM
WNDOPDLR's Avatar
WNDOPDLR
Thanks guys. This forum is so cool. Put the fuel pump into constant run and that allowed me to figure out that I had the lines reversed. Seemed logical to me that preasure should go to the regulator, but so much for logic. Reversed the lines and everything seems to be working fine. Thanks again for the help.
Old Mar 19, 2005 | 07:20 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Yeah, the regulator comes after the rail. It basically acts as a restriction to hold pressure in the rail, and 'regulate' how much returns to the tank.
To Fuel Pump Jumper
