Problems....
Old Mar 19, 2005 | 10:18 PM
jabez's Avatar
jabez
Default Problems....
Try to start my 92 auto today. Turn key and nothing. Did not even turn over. Battery seemed OK Lights, radio, etc were strong. Also it is new installed three weeks ago. I sit there trying key with nothing for about 5 minutes then it roars on. Drove it about twenty minutes and it drove fine. While driving security light flashes on and service ASR lightes up.
So whats up with car?? TIA
Old Mar 19, 2005 | 10:49 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If the lights did not dim when you hit the start key position the problem is either the VATS system or the neutral/park safety switch; my bet is on the VATS unless you wiggled the shifter between start up attempts.
I have no clue on the ASR issue.
Old Mar 19, 2005 | 11:03 PM
jabez's Avatar
jabez
Lights didn't dim.
On the VATS issue, can that be disabled? Or what is the fix?
Old Mar 20, 2005 | 12:01 AM
mstock's Avatar
mstock
Default Vats
I don't know about your car, but on my 84, in the multiuse area in the dash, there is a fuse you can pull to disable the vats system.
Old Mar 20, 2005 | 02:39 PM
jabez's Avatar
jabez
I decided to wiggle the shifter a bit and it starts right up.
Old Mar 20, 2005 | 02:50 PM
c4cruiser's Avatar
c4cruiser
Sounds like the shifter cable is out of adjustment. Does the steering wheel lock and can you remove the key when you put the shifter into Park?? There is also a switch that allows starting in the Neutral position. Does that work??
Old Mar 20, 2005 | 05:15 PM
jabez's Avatar
jabez
Have no problems with steering wheel lock or removing the key.
To Problems....
