another problemo
Old Mar 20, 2005 | 02:34 PM
jabez's Avatar
jabez
Default another problemo
Got car started. turn off key and pull it out. The motor keeps running for another 5 secs (scares the hell outta me) , car shakes badly then stops. Take a chance and try to duplicate and can't. Now starts everytime and turns off everytime correctly.
What happened? Alternator warning sign?
Old Mar 20, 2005 | 02:45 PM
MrRenoman's Avatar
MrRenoman
Sounds like the ignition is staying on and the residual pressure in the fuel system is burning off which may cause the stumbling you're experiencing til it dies. Seems strange that the park/neutral safety switch and the ignition switch (not the ignition key tumbler) are both acting up.
Art
Old Mar 20, 2005 | 03:25 PM
JAKE's Avatar
JAKE
During that 5 seconds, does the engine shake and/or make unusual sounds?
Jake
Old Mar 20, 2005 | 03:43 PM
vetster86's Avatar
vetster86
Sounds like pre-ignition or dieseling, bad gas can sometimes cause this or timing/overheating.
Old Mar 20, 2005 | 05:08 PM
jfb's Avatar
jfb
Preignition cannot happen with the ign switch off because the ECM does not pulse the injectors. No fuel, no run. What you experienced was the ignition switch not being turned off all the way when you pulled your key out.
Old Mar 20, 2005 | 05:11 PM
jabez's Avatar
jabez
Jake
yes..the sound is like a whining.
Old Mar 20, 2005 | 06:45 PM
JAKE's Avatar
JAKE
There's a condition we use to refer to as "Run-On"; the squad cars were notorious for it. The engine would continue to run, knock like crazy, shake and give off an awful smell.
Some would continue to run until the engine was again started, trans put in gear and the key turned "Off".
Bad or low octane gas coupled with glowing combustion chamber parts or carbon was how it was explained to me.
What you're explaining doesn't sound like that though.
If it recurs you might want to try a higher octane gas unless you're running the max already.
You can also allow the engine to idle for 30 seconds or so before shutting it down.
Jake
Old Mar 20, 2005 | 06:58 PM
vetster86's Avatar
vetster86
Dieseling/pre-ignition/engine run-on, has nothing to do with the ecm.
Its a condition in which hots spots in the combustion chamber (carbon deposits/ unburned fuel) cause the engine to run on after the key is turned off.
Old Mar 20, 2005 | 07:04 PM
86C4EVER's Avatar
86C4EVER
but, dont you also need fuel? I thought run-on occured with mechanical fuel pumps because as long as the engine ran, it kept fuel coming. With the Vette system, can that happen?
Old Mar 20, 2005 | 07:43 PM
vetster86's Avatar
vetster86
Excess FUEL (or build up of carbon deposits) that was not burned during the combustion stroke, hot spots in the combustion chamber can fire the excess FUEL or carbon deposits and cause the engine to run-on when the key is turned off.
Old Mar 20, 2005 | 07:58 PM
86C4EVER's Avatar
86C4EVER
OK, this time, I got it. Dont you just love it when you have to say the same thing over and over again?
:o
Old Mar 20, 2005 | 08:04 PM
vetster86's Avatar
vetster86
:o
Thats OK! my kids tell me I never explain things right the first time.
Old Mar 20, 2005 | 08:12 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Could also be leaking injectors. They would cause the carbon deposits from an overly rich mixture during normal running and also supply some fuel after the ignition has been shut off.
Just a thought
To another problemo
