E.T. with 2.59 gears
Old Mar 21, 2005 | 04:38 PM
rlane5's Avatar
rlane5
Default E.T. with 2.59 gears
Hi all,
What is the quickest, that anyone has gone (1/4) with 2.59 gears and L98 and 700R4 ?
Randy,
Old Mar 21, 2005 | 05:48 PM
ConeKLR's Avatar
ConeKLR
Cruise-In II Veteran
I have gone 13.8et@98mph on street tires bone stock 91 L98 auto w/2.59 rear
Old Mar 21, 2005 | 08:42 PM
TA's Avatar
TA
If I recall correctly I went about 13.30 when I still had my 2.59s. Its really not that bad of a rear in an L98. I think my 60' time was around 1.80 or so with drag radials.
Old Mar 21, 2005 | 10:23 PM
pipe's Avatar
pipe
I went a 13.63 with street tires and hooker headers through the stock cat convertor and mufflers. Also a very few minor bolt on's. My car ran worse this past weekend with the 3.07s
Old Mar 21, 2005 | 10:28 PM
65Z01's Avatar
65Z01
My best times are in my sig with some bolt-ons and stock cam, heads and headers.
Last Sat. at Englishtown I was still down on power and ran low 13.4s at around 100mph with 1.89sec short times.
Old Mar 21, 2005 | 10:52 PM
scofolo's Avatar
scofolo
I have a true dual exhaust system with no cats and borla mufflers. I also have a cut lit with K&N and removed Air pump and frisbee. My best time is in my sig. This was on street tires and 2.59's with my A4.
Old Mar 21, 2005 | 11:01 PM
cv67's Avatar
cv67
St. Jude Donor '05
1.89? Goodyears or drag radials? That's pretty good!
Old Mar 21, 2005 | 11:44 PM
krivera's Avatar
krivera
14.9 at 6000feet above sea level
K
Old Mar 22, 2005 | 12:01 AM
shepsvettes's Avatar
shepsvettes
I have gone 12.9 at 111 mph but my 100 shot of Nitrous really helped things out
Old Mar 22, 2005 | 12:23 AM
65Z01's Avatar
65Z01
cuisinartvette, yes it was on a new set of GY Eagle Ultra HP Plus, stock 17" size tires at 29-30psi.
All morning & after noon the track was very tight and gave a dead hook every time. Early in the evening we had 3 successive oil-downs around sunset and the track went away, as did my good short times.
Old Mar 22, 2005 | 12:59 AM
Zrxmax's Avatar
Zrxmax
2nd ever run was 14.03 at 95 mph Sacamento CA... elevation unknown... it was my old 35th Anniversary model with 104 thousand miles on it... New owner claimed 13.90s...
Old Mar 22, 2005 | 10:44 PM
Mad-Mic's Avatar
Mad-Mic
here is my best timeslip from last year and it was in spring. fall racing season i was fighting codes and the car was down on power.
Current Mods when this run was made:
K&N open air box, MAF descreened, TB Bypassed, 160* T-Stat, Accel Super Coil, 12* degree advance timing, TPiS Long Tube Headers, !Air, !EGR, and dumps off the rear Y pipe. Hayden Tranny cooler. Stock 1600 rpm stall, 2.59 rear gear on 275/40/17" BF GoodYear F1 D3 285/40/17" at 18 psi.
added a few mods since then and should go a hair faster
i'm gonna keep the D 36 with the 2.59 gears until it breaks. next up is a 388 stroker with 3200 stall and some juice with a progressive controller down the road so i can come out of the hole easy with a small 30 shot and in 3 seconds or so be at the full 150
Old Mar 23, 2005 | 12:36 AM
kopbet89c4's Avatar
kopbet89c4
I'm starting to like 2.59s compared to my 3.07. I bet you all have better gas economy and do high speed cruises at a lower RPM. 80 mph @ 2000 rpms sounds better than my 70 mph @ 2000 rpms.
Old Mar 23, 2005 | 10:58 AM
Mad-Mic's Avatar
Mad-Mic
launching on the street is easier too at 80 mph i think i'm turning 1800 rpm?!?! i can tell you at 5100 rpm in drive going to OD what i'm hitting!
Old Mar 23, 2005 | 12:03 PM
mn_vette's Avatar
mn_vette
I managed a 12.4 with my LT1. It was weird, I ended the runs just before I hit the revlimiter in second gear. I've got a 3.45 now with a higher stall converter, launching is harder, but those 60' times went from a 2.0 to a 1.7X if I launch right on street tires.
Old Mar 23, 2005 | 12:39 PM
mike 1985's Avatar
mike 1985
repoman went low 12's with his L-98 700r-4 and 2.59' ..i know it was sprayed too, i don't remember how hard .
Old Mar 23, 2005 | 03:05 PM
AdamBlattel's Avatar
AdamBlattel
Default 1995 ET with stock 2.59 Third member...
I ran a 13.995 with stock 2.59 rear in the 95 LT-1 we got. There nice milage gears but they are not for drag racing...Changing to 3.55 cuts about .5 second of our ET with just gears. Pretty Amazing...
Adam
Old Mar 23, 2005 | 05:48 PM
88BlackZ-51's Avatar
88BlackZ-51
i find it amazing with our L-98 that the E.T. isn't bad.....13.18@105 or so.......but we never seem to trap high, i guess that is the low chp, and the high torque that does that.
my friend has a bone stock 02 SS that traps in at 13.2@108.5 with a 1.99 60 foot. no pun at all. the LS-X motors are unbeatable when it comes to making power.
that is why if i race a LS-1, It has to be from a dead stop or i will get spanked pretty hard.
Old Mar 23, 2005 | 08:20 PM
Mad-Mic's Avatar
Mad-Mic
is your friend an M6 6 speed car? if so thats why. manuals don't eat up as much HP as auto's do. plus with 4 more u-joints that eats up even more.
if i made power upto 5800 rpm in 5800 rpm in 2nd gear i'm at 101 mph.
come on 388 roller stroker with my LT1 intake
To E.T. with 2.59 gears
