o2 sensor
Old Mar 21, 2005 | 08:55 PM
dm1948's Avatar
dm1948
Default o2 sensor
about a month ago i changed my o2 sensor because i was getting
black carbon out of the tailpipes so i replaced the sensor and ran
seafoam threw it for about a 100 miles, i'm still getting black stuff
out of the tailpipes, how long does it take to blow that stuff out
or is thier something else i can do?
Old Mar 22, 2005 | 02:23 AM
rebuildman's Avatar
rebuildman
Black is rich as you know, how do the spark plugs look? If they to are black, too much fuel, or not being burned correctly. Fuel pressure?
Old Mar 22, 2005 | 08:09 AM
rick lambert's Avatar
rick lambert
If you followed the Seafoam directions-1/3 of can thru vac line and kept the RPMs up around 1500-2000 it should have removed the carbon deposits almost immediately (been using it for years). You might want to check your EGR to make sure it's operating properly, a stuck EGR valve or bad EGR switch can make it run rich-and your mileage would be poor.
Old Mar 22, 2005 | 03:23 PM
Lone Ranger's Avatar
Lone Ranger
Is this because it makes it like a vacuum leak, sort of?
To o2 sensor
