LT1 STRIPPED spark plug holes
Now, aside from being thoroughly disgusted with my purchase from ORANGE PARK DODGE in Jacksonville, Florida, I'm just dreading the time and money that will be required to fix this problem. If I already have to pull the heads with 94,000 miles on the engine, the can of worms is wide open for everything imaginable.
Does anyone have any advice for pulling LT1 heads? Ahem, constructive advice, please! :-) Ever had plug holes repaired in aluminum heads? I don't like the thought of helicoils for this, but is there any other option available besides buying another set of heads?
The previous owner/shop did not use anti seize on the plugs. The #8 plug was impossible to get out. I ended up using a breaker bar with an extension that helped move the plug while in the head bending the threads.
After looking into alternatives, I said funk it, and ordered a set of rebuilt heads from a LT1/4 shop in Houston that also did a very mild job on the heads. Without the work on the heads, I think I would have been out the door in the 200-250 range with shipping my heads backto them.
Its pretty much impossible to do anything to the head while on the car, or so I came to see.
So, if they are that bad, and you don't want to helicoil them, see if there are any shops around you that work on heads and you can swap for cores. Perfect time to upgrade. I got new valves, new LT4 springs, and 1.6 RRS along with the head work. If you can remove/install the heads yourself, you are saving a lot of money (local shop here in ATX quoted me $800 to remove and reinstall the heads.
I got good at taking these things off, as I can get both heads off in about an 2 hours.
Ford has had a major problem in their modular truck engines, namely the 5.4 and their V10 engines has had problems with spark plugs blowing out, and I am not talking about one that blows out as a result of improper torq by the owner or a Goober type mechanic. I am talking about the originally installed spark plug at the Ford factory blowing out. I have seen three instances of this happening. For some reason the plug works loose and starts leaking exhaust gases, in time the gases errodes the thread and out comes the plug. In all instances I have referred the customer to their dealers, I didn't even wanna think about pulling a head on one of them things.....
Any competent machine shop should be able to repair your heads. Stripped plug threads are a common problem and are easily fixed with an insert or using heli-coils.
Tjwong- what cylinder on the customer's LT1 did you repair? I can see #5 and have a decent shot at reaching it, but I'm not so sure about #8. Also, what type of kit did you use? I found the following link last night:
http://www.timesert.com/sprksert.html
Anyone ever heard of these guys before or better yet, used their kit? Right now I'm just disgusted thinking of what it may take to get my baby on the road again. Driving my 91 pickup is really bringing me down! :-)
I've never dropped the exhaust from a vette, but I anticipate a high PITA-factor there. I don't suppose just unbolting the exhaust manifolds from the heads and leaving them attached to the rest of the exhaust will give me enough room to pull the heads?
As for the fuel rail and intake, is it possible to pull the two as a unit on an LT1?
Pulling the heads doesn't scare me, just getting all the other parts off so I can get to them is what's got me concerned. I've got ample tools, but my time is limited and so is my available garage space. I don't want to turn this into the never ending project. Inevitably, I'll find other issues that I can't live with and will have to fix them too.
Why oh why did I just HAVE to buy THIS particular car??? It's almost like marriage...six months of blissful happiness then one day the honeymoon comes to a screeching halt!
I would go back to the Dodge dealer you bought it at and let them know your problem and that their service techs are a f'n joke. They won't do a damned thing, but it will make you feel better for saying so.
Next up, remove the heads. Trust me, you should not attempt to fix this on the car. The angles are a bitch to start with, and your one shot with a helicoil won't work. Besides, you don't want to get ick in the cylinders, either.
if it was me, I would pull the motor and refresh it. At this point it won't take much more and you will then have a known quantity.
The first time, I pulled the exhaust manifolds off because I found some shorty headers real cheap. The second time I pulled the heads, I just undid the bolts from the shortys to the block and left them hanging.
If you want to remove the exhaust manifolds, add more time. There is one bolt on each side at the bottom of the exhaust manifold that requires a wiggle, and when these bolts have never been removed, it is a pain. I ended up busting one of the studs off the original manifold since it was so rusted together (this was after soaking several hours in all sorts of liquid wrench).
I took pictures of everything before i pulled everything apart, if you choose to take the heads off yourself, take pictures.
Also, you will need to know how to set the lash on all your valves, which is pretty straight forward as well.
Some of the other repair inserts are solid and threaded on the inside and outside, they install about the same way as a helicoil.
The guy brought me the cylinder head, so I had it very easy
I know this sounds very cynical, but I don't really have much faith in local establishments being "competent" anymore. Anyone know of well-known, reputable shops that specialize in vette heads?
Secondly, your options if you have nobody local are: Find a shop and ship them your heads, or buy a set of aftermarket or replacement heads.
If you have any racers in your area (not the Goober type, but true fast running types), ask them who does their machine work.
If you're repairing your heads, it makes sense with 90,000+ on the clock to have the heads reconditioned (valve job, seals, etc.) at the same time...now is NOT the time to be a "gator-arm" as we call it in Florida (arm too short to reach into the wallet
). It's always a bummer to find "hidden" problems after the sale, but that's how it is.Good luck, whatever you plan to do.
May I suggest an option - factory GM heads are CHEAP on the used market. Find a good machine shop, they can get you these heads, clean them up and you will be done.
The other option is Edelbrock, Dart, AFR or any number of aftermarket head makers. But remember - this option will not leave much change from $1500.00.
I would, at the very least, ditch those heads. And I would drop them on the foot of the service manager at the dealership who screwed this job up.
