anyone know how mutch of a performance gain can be had
switching to roller rockers ?. how hard are they to install ?.
what brand are the best to buy ?. any ideas please
1986 L98 tpi
Reason: did not include engine
I suggest you consider roller tip rockers instead of full roller (roller fulcrum and tip). Full roller rockers are not the best for a street engine as they tend not to be as durable over high mileage. Roller tips ,on the other hand , can add significantly to the life of the valve guides since they virtually eliminate the typical side loading of the valve stem as it cycles up and down the guide.
You will not see a noticable gain in power with either full roller rockers or roller tips at the standard 1.5 ratio. You may want to try 1.6 ratio especially on the intake. the 1.6 ratio wil not only increase lift but also slightly increase duration.
While you are in the valves , it's a good idea to change the seals.
I did the 1.6 rockers on my "stock" 84 Xfire a number of years ago. It helped along the lines of about 10-12hp. I tried a 1.6I/1.5E combination and liked that quite a bit too.
