My car is a 95 and, as far as I know, completely stock. From what I've read as LT-1's redline is 5500 rpms, which is where the rev limiter kicks in. Last night when I left work i pulled out of the parking lot and stood on it, WOT. At around 5500 rpms the car shifted into second. The instant that it shifted I saw the tach pass 6000 for a split second. The rev limiter didn't kick in, and now I'm curious if this is actually a "quirk" (for lack of a better word) of the tach itself. This isn't the first time I've seen it do this. So I'm wondering, anyone else ever see something like this before?
At higher RPM's, I found my tach to be off by 700 RPM. Alot of other folks here experienced the same thing. I would guess yours is a bit off too. A dyno run can tell you for sure.
The stock rev limiter is 5850. It acts by cutting off fuel, and there is a delay until the pressure goes down in the fuel rails. You can overrev the limiter in 1st and 2nd on a 6 speed, then it will seem to cut off at lower revs in 3rd and 4th. Time is the factor here. The engine revs so quick in 1st that the tach is farther behind than it is in 3rd and 4th. So you aren't seeing a true reading on the tach. I believe my tach is close to right on in 3rd gear going through the 1/4.
I have my limiter bumped to 6400 and try to shift at 6200 by the tach. I don't normally hit the rev limiter going through the 1/4, I only bounce off it when there is horrible traction.
5850 is stock and the factory tach can only move so fast. Thus your rev limiter will appear to be different places depending on what gear you're in and how far you've got the pedal to the floor.
Question though? I know the factory limiter works by dropping fuel. Wouldn't it do this by cutting the injectors, thus it would be instant. Cutting the fuel pump would take a LONG time to have a noticeable effect.
Anyway, I've got an MSD digital 6 set at 6500 RPM's and the factory limiter is programmed out of the way. For the track I have a shift light that comes on at a preset RPM no matter what the tach actually reads.
Thanks for the info, good stuff to know. I had a feeling that it was the tach since the rev limiter never kicked in. I assume that GM probably programs there rev limiters a bit conservatively to prevent idiots, like me, from doing damage to engines in cars under warranty.
I've seen this happen in my car a few times. I was a little concerned, but more curious than anything.
If I had to take a guess... I would have to say that it does cut the fuel at the injectors. My 4-cyl. S-10 dd has a fuel shut off set a 98 mph. The instant it hits 98 mph the fuel shut off, which functions the same as the rev limter does, kicks in. If it cut the fuel at the pump, then all the fuel between the pump and the injectors would still be used, meaning it would still accelerate. Well, accelerate as much as 4 cyl. could, which isn't a whole helluva lot. So, I believe that it does kill the injectors.
I'll kills the injectors not the fuel pump (that would take WAY too long). If you've ever pulled the fuse it can take a couple seconds before the engine dies.
:Question though? I know the factory limiter works by dropping fuel. Wouldn't it do this by cutting the injectors, thus it would be instant. Cutting the fuel pump would take a LONG time to have a noticeable effect.
I thought I read it somewhere, but maybe I was told by John Sealock when he told me to up my rev limiter and shift lower. Maybe he's got it flat wrong. He was warning me about an instant lean condition when the engine hits the limiter.
It makes sense that the PCM has knowledge of the rpms and has full control of the injectors, so that's the correct way to cut off some cylinders. If the injector is not fired at all then there is no lean condition to harm the engine.
Lord knows, as much as Mojo hits his limiter he should have blown it up by now if there was a problem.
I swear I got well beyond 5850 by the tach in 1st when i hit the rev limiter, but got cut off at 5850 in 3rd. I never have hit it in 4th or 5th so I don't know what happens in those gears.
